Phoenixarcade ArcadeSD - Programmable multigame JAMMA PCB
http://www.phoenixarcade.com/ArcadeSD.htm
http://www.youtube.com/watch?v=vKIHwMVDRZo
ZitatAlles anzeigenFaq: http://www.gamma-arcade.com/ArcadeSD/ArcadeSD_FAQ.pdf
· 2 Gigabyte SD Card capacity for hundreds of games (sold separately)
· MP3 Jukebox Game (similar to Guitar Hero) plays back MP3 files from SD Card
· Quarterly projected (but not guaranteed) firmware updates (January, April, July, October)
· All high scores saved on SD Card and retained when game turned off
· Supports both VGA and CGA monitors (CRT or LCD)
· Supports standard 8-way joysticks, Happ style trackball, and Happ/Midway 49-way joystick controls
· 49-way joystick automatically translated to 4-way, 8-way, and diagonal-only sticks
· Lightgun control input supported for gun games
· Supports either amplified JAMMA mono speaker output, or line level pre-amp output for stereo sound
· Animated game icon menu navigation for quick game selection
· Access to all game and cabinet settings through PC setup application and on-screen menu
· SD Card stores statistics of games played, time played, coin counts, etc.
· Entire collection (as of 9/1/11) of upright and horizontal games fits on a single SD card
· Switch between upright / cocktail / horizontal mode from onscreen menu
· Purchased games unlocked by Serial Number, no codes to remember
· Small footprint 3.5" x 4.5"
· Dynamic menu system is automatically built with the games you load/select
· Animated menu with icons and game marquees
· Enable or disable games from menu
· Game variations (faster speed, auto fire, etc.) available from Game Options menu
· Optionally disable panel controls until coins are inserted
· All control axis/directions can be changed in setup (no need to re-wire your trackball unit)
· Arcade and free play modes
· All credits are global and can be shared between different games
· On screen configuration/setup menu
· Built in, on screen hardware diagnostics (tests video, audio, inputs, coin counters, LEDs, etc.)
· Test mode button on board (JAMMA harness "test" input also supported)
· CGA/VGA mode selection button on board
· PCB only requires +5 V.D.C. power (uses less than 1A at full volume)
· Software controlled volume adjustment
· Field programmable by the end user
· Built in two-channel lamp/LED driver (use for Atari 'cone button' lights & buttons, etc.)
· 30 Day manufacturer warranty covering manufacturing/parts defects (see warranty for details)
Features subject to change without notice. Phoenix Arcade LLC retains the right to discontinue sales and support of the ArcadeSD without notice. However an effort will be made for one final firmware update.
... schreibt was!!!!
