Mal ohne große Worte:
test/solved: (dd-mm-yyyy) (please specify date in CET)
- 19-05-2004 changed: subtitles now default to be off.
- 19-05-2004 fixed: DVD subtitles weren't displaying and wasn't possible to switch.
- 18-05-2004 fixed: unable to play a .pls file with items like http://12.54.64.32/music/file-1.mp3
- 18-05-2004 changed: Select dialog, Hidding button on the left when not used
- 18-05-2004 changed: album info: shows albumname too, when inexact matches are found
- 18-05-2004 added: album info: manual album lookup
- 18-05-2004 changed: album info: refresh button requeries allmusic.com
- 18-05-2004 added: support for flipping hebrew subtitles
- 17-05-2004 fixed: shoutcast name resolving and some shoutcast crashes
- 17-05-2004 fixed: enlarge subtitles
- 17-05-2004 fixed: after the CURL change samba leaves a lot of open session on the server
- 16-05-2004 fixed: scroll suffix in skin files was ignored for thumbnail panels
- 16-05-2004 fixed: make sure file exists before trying to cache it when looking for folder.jpg files.
- 16-05-2004 fixed: samba didn't connect with domain information to server. allways disregarded it.
- 16-05-2004 fixed: samba didn't stat with utf8 formatting.
- 16-05-2004 changed: fileprotocol changed to take a CURL as parameter instead of separated values.
- 16-05-2004 fixed: If your nameserver is not working properly, default to using IP address for known hosts (weather, imdb, allmusic).
- 16-05-2004 added: more logging for samba + removed some bugs from bugs.txt that did not exist anymore
- 16-05-2004 fixed: streaming from internet when multichannel (passtrough) output is selected.
- 16-05-2004 fixed: Q:\albums directory had to exist for the databases to create even though your specified a different <albums> location in XboxMediaCenter.xml.
- 15-05-2004 play a video, stop. go into settings -> my video: big white area covering most of the screen
Naja, is die neue version
bis denne................
