WinUAE Loader v1.6 - By HeadKaze
-: About :-
WinUAE Loader is a WinUAE launcher for arcade cabinets. It supports GameBase Amiga, SPS and WHDLoad game sets and allows you to remap input to suit arcade controls.
-: Features :-
- Map inputs to any arcade control panel layout (default set for IPAC)
- Support for GameBase Amiga, SPS and WHDLoad game sets
- Global exit key (default ESC)
- Single button Disk Swapper (default 'P')
- Mouse emulation (use Joystick for mouse games)
- Ability to hide CLI when launching WHDLoad games
- Includes database and map files for GameEx frontend
- Renames artwork such as title screens, screenshots and box art to match game filenames
- Can update data files dynamically using the GameBase Amiga database
- Run games in the configuration gui for testing
-: USAGE :-
WinUAELoader.exe -mode [gamebase|whdload|sps] -game "file"
Eg. WinUAELoader.exe -mode whdload "NinjaRemix_v1.3.zip"
Run WinUAELoader.exe to show the configuration gui
-: Release Notes :-
01-07-2008 - v1.6 - Updated GameBase Amiga database to 2.6. Added support for GameEx's new database format.
16-06-2008 - v1.52 - Separated screen, depth and refresh rates. Added 50Hz (PAL) support.
08-05-2008 - v1.51 - Fixed bug when display not set launching from command line
30-04-2008 - v1.5 - Added extra display options
07-02-2008 - v1.41 - Added variable mouse speed
07-02-2008 - v1.4 - Mouse emulation added (use joystick for mouse games)
07-02-2008 - v1.39 - Converting artwork now places files in separate folders for GameBase/WHDLoad/SPS
05-02-2008 - v1.38 - Fixed input mapping bug
03-02-2008 - v1.37 - Added support for Boxscan artwork
03-02-2008 - v1.36 - Added filtering for GameEx map generation.
03-02-2008 - v1.35 - Can now select from Title Screen, Screenshot 1 or 2 screenshot formats
02-02-2008 - v1.34 - Can now convert screenshots without GameBase Amiga database
02-02-2008 - v1.33 - Bug fixes
01-02-2008 - v1.32 - Changed Input Mapping defaults so there is less chance of a conflict
01-02-2008 - v1.31 - Added friendly error message in log when game is not found
31-01-2008 - v1.3 - Added single button disk swapper
31-01-2008 - v1.21 - Fix for simultaneous games that don't use two joysticks
31-01-2008 - v1.2 - Removed "Force Use Mouse". Now you can set any control for port0/port1. If you want the mouse permanently in port0 just set it to Mouse.
31-01-2008 - v1.1 - Mouse is now disabled for simultaneous games. Added delete temp files for WHDLoad. Two player game ports are now swapped over. New "Force Use Mouse" option to turn on mouse for all games.
30-01-2008 - v1.02 - Fixes to when the control key is used in input mappings
30-01-2008 - v1.01 - Fixed control error in databases
30-01-2008 - v1.0 - Added auto switching for PAL/NTSC
30-01-2008 - v0.91 BETA - Added "Generate Map Files" with ability to remove missing games for GameEx. Key mapping is not turned off when WinUAE is not running.
30-01-2008 - v0.90 BETA - First Release
Anleitung zum einbinden in Frontends, bevorzugt Gameex gibts im Original-Thread. Nämlich HIER
