Mame 0.135
    • 0.135
      MAMETesters Bugs Fixed
      - 03378: [DIP/Input] kamakazi3: Unable to use normal coin slots (coin
      lockout) (Luigi30)
      - 03496: [Sound] mouja: Sound Effects/Voice missing (Mamesick)
      - 03423: [Crash/Freeze] acpsx, atpsx, atluspsx, cpzn1, cpzn2, psarc95,
      taitofx1, tps, vspsx : Access Violation (Fabio Priuli)
      - 03425: [Crash/Freeze] taitogn: Access Violation before typing OK.
      (Fabio Priuli)
      - 03424: [Crash/Freeze] chihiro, triforce: Access Violation before
      typing OK (Fabio Priuli)
      - 03490: [Crash/Freeze] quasar, quasara: Segmentation Fault after OK
      (Fabio Priuli)
      - 03491: [Crash/Freeze] dynobop, sstrike, slikshot, slikshot17,
      slikshot16 : Access Violation after OK (Phil Bennett)
      - 03487: [Crash/Freeze] All Drivers using z180 cpu: Access Violation
      (Phil Bennett)
      Source Changes
      Changed sound banking on Shogun Warriors/B.Rap Boys to use an
      OKIM6295 address map and banks [David Haywood]
      Removed the MCU comm hack from namcofl/namconb. This now fixes the
      music tempo in most games. [Phil Bennett]
      Fixed vroulet controls so that the Red column can be selected.
      [luigi30]
      680x0 update: [R. Belmont]
      - Support PMOVE modes from PMMU
      - Allow the FPU to be used for both '030 and '040
      - Add byte and word FPU loads/stores
      - Fixed buggy FPU 64-bit stores in the (An) addressing mode
      chdman: add option to create uncompressed writeable HD images for MESS
      [R. Belmont]
      scsihd: don't crash if no media is attached [R. Belmont]
      More goldstar.c improvements... [Roberto Fresca]
      * Completed the New Lucky 8 Lines / New Super 8 Lines hardware/PCB
      layout.
      * Added New Lucky 8 Lines (set 3, extended gfx).
      This set has the New Lucky 8 Lines / New Super 8 Lines program, so
      bets are up to 64. Same extended tileset for reels, but lacks of
      the New Super 8 Lines title tiles. Maybe is a hidden feature,
      maybe just graphics for another hack.
      * Added technical notes.
      Added abort button to sfrush [Arthur Peale]
      Updated mt_tout CRC/SHA1 and added note about old, likely bad dump
      [David Haywood]
      Added missing dependencies for video/model2.c and video/model3.c
      [Phil Bennett]
      Fixed recent sprite breakage in some toaplan2 video HW-based games.
      [Phil Bennett]
      Added later version of Naomi analog I/O board program [Alex]
      Changes to the dsp56156 cpu core. [Andrew Gardner]
      * Added JF table decode function.
      * Added ABS, IMAC, and TFR2 opcodes.
      * Fixed various flags for TST, INC24, SUB, CMP, and CMPM.
      * Added hack to DO function to accommodate for the CPU core's
      inaccurate math.
      Galaxian driver changes: [luigi30]
      * Crystallized some clock speeds, put ?s near ones that didn't look
      correct
      * Changed references to galaxiaj in game names to galaxiana
      Re-added 2nd button back to ddayc [David Haywood]
      Documentation update for the Seibu COPDX-based games. Renamed
      sdgndmrb to grainbow. [David Haywood]
      Updated most tools in src/tools to be straight BSD license.
      [Aaron Giles]
      Added -flipped option to unidasm to output with disassembly first and
      address/data bytes afterwards in comment form. [Aaron Giles]
      Changed 32010 unknown opcode to output in $xxx format like all other
      hex values. [Aaron Giles]
      Mahjong Seiryu Densetsu [Luca Elia, Guru, Dyq, Bnathan]
      Mahjong Daimyojin [Luca Elia, Guru, Dyq, Bnathan]
      New clones added
      Pinball Action (set 5, encrypted) [f205v]
      Hyper Sports (bootleg) [f205v, David Haywood]
      Darkstalkers: The Night Warriors (Hispanic 940818) [Artemio]
      Gran Premio F1 (Italian bootleg of Pole Position II)
      Scramble (Karateko, French bootleg) [Joachim Bassmann]
      Super Breakout (rev 03) [Andy Welburn, Lord Nightmare]
      [Roberto Fresca, Darklord & Team Europe]
      Tournament Solitaire [Angelo Salese, Siftware]
      Airline Pilots DX [ANY, The Dumping Union]
      Cablos
