Mame 0.138u4
    • Mame 0.138u4
      0.138u4
      MAMETesters Bugs Fixed
      - 02813: [Sound] amerdart, amerdart2: No sound due to missing ROM
      (Quench)
      - 03606: [Multisession] altbeast, aliensyn3: Graphic corruption on
      multiple segas16b.c launches in single session. (Atari Ace)
      - 03536: [Misc.] PowerPC core: Overlapping data buffers (Atari Ace)
      - 03943: [Graphics] tknight, wildfang: The screen shaking effect is
      missing in MAME. (hap)
      - 00790: [Documentation] armwrest: DIP switch inspection. (hap)
      - 03938: [Crash/Freeze] torus: Crash after completing Level 1
      (Fabio Priuli)
      - 03928: [Crash/Freeze] Many sets: Out of memory crash using -cheat
      (Aaron Giles)
      Source Changes
      Fix SH-2 interpreter [Atari Ace]
      fix xmcotah/xmcotahr1 ROMs [Razoola]
      turned i2cmem into a c++ device & ditched the unused legacy device.
      [smf]
      Added per-device image softlist loading routine [Miodrag Milanovic]
      Renamed feof to image_feof (in device_image_interface) in order to
      compile on FreeBSD [El Barto]
      Removed devtag_get_device(); use machine->device() instead.
      [Aaron Giles]
      Removed the global clock accessors and cpu_* aliases: [Aaron Giles]
      cpu_get_clock == device->unscaled_clock
      cpu_set_clock == device->set_unscaled_clock
      cpu_get_clockscale == device->get_clock_scale
      cpu_set_clockscale == device->set_clock_scale
      Fix bad loop condition that shows up with -cheat enabled. [Aaron Giles]
      Adding ability to support other types of software lists, so floppies,
      cassettes, cd-roms are now possible to be used [Miodrag Milanovic]
      MAMEdev kant spel (Ubuntu/Canonical cares about this) [wallyweek]
      Add *IX man pages for MAME and utils [wallyweek]
      Clean up some files without a newline at the end for GCC [wallyweek]
      Added second button (Hyper Jump) to be used after cued via speech to
      allow jumping to other phases without finishing the current mission.
      Volume adjusted to better levels (AY was way too low in comparison to
      speech) [gravilidavide, Tafoid]
      snowbros.c: Add Dipswitch locations to Puzzle King, Hyper Pacman,
      Cookie & Bibi 2, Cookie & Bibi 3, More More. Filled in dips with
      Dipswitch locations for Puzzle Break. [Brian Troha]
      Load (but don't yet use) the decapped MCUs for several sets
      [Dr. Decapitator]
      * kyros
      * kyros (alt, original MCU dump?)
      * arkanoid (I think the supported MCUs are bootlegs..)
      * blackt96
      * amerdarts
      * cshooter
      * josvolly (there are other chips still need decapping)
      * invasnab (i'm not convinced this one is good)
      * pasha2
      * empcity
      * topshoot
      * topbladv (no CPU core for this yet)
      * officeye (no CPU core for this yet)
      * revx
      Added the proms to Magical Odds [Smitdogg, The Dumping Union]
      converted at28c16 to a c++ device. [smf]
      arkanoid.c: Added or corrected the PCB location for the genuine
      Arkanoid rom sets and documented the MCU Taito ID number [Brian Troha]
      Replaced the old MCU dump with the decapped version for Kick Start
      Wheelie King [Dr. Decapitator]
      Replaced the old MCU dump with the decapped version for Pipeline
      [Dr. Decapitator]
      [cb2001] new opcodes [robiza]
      Fixed image unload and creation [Sandro Ronco, Miodrag Milanovic]
      cb2001: hooked up reels [David Haywood]
      Rewrite of 'Wheels & Fire' driver [Tomasz Slanina]
      * new rendering code
      * preliminary zooming (based on lookup table)
      * preliminary communication between main and sound cpu
      * scanline interrupts and scroll
      segas16b.c: Removed 2 obsolete "USER2 Work space" and changed
      remaining USER2 to MCU to maintain consistence throughout the driver.
      [Brian Troha]
      Added information on the Naomi 171-8346C cartridge type [f205v]
      'Massive' Neo Geo documentation update [Johnboy]:
      * Added official SNK Playmore title catalogue
      * Identified and tagged all MVS sets which were not officially
      released for the AES system (according to official SNK Playmore
      title catalogue and Neo-Geo Masterlist)
      * Several sets have been identified (AES / MVS VERSION) and tagged
      properly
      * Documented MULTI PLAY MODE (unemulated); Missing MCU
      * Updated game PCB information
      * Renamed kof99n to kof99k (KOREAN VERSION)
      * Renamed P's in mslug3 to correct chip label, added SMA comment
      * Renamed ROMs in jockeygp according to original cart, added some
      comments
      * Renamed ROMs in vliner/vlinero according to original cart, added
      some comments
      * neodrvr.c cleanup
      Fixed some bugs in the MB88xx CPU core [Alex Jackson]
      Various improvements to polepos.c [Alex Jackson]:
      * Corrected the way the steering wheel is hooked up, fixing the
      jittery steering in the sets with MCUs.
      * Added a new layout file for the bootleg sets without MCUs
      (topracern and polepos2bi).
      * Converted clock frequencies to crystal values from xtal.c.
      * Added correct ROM names for the Namco-manufactured sets (polepos
      and polepos2).
      * Completely removed the unused global variable polepos_gear_bit.
      * Fixed a couple of bootleg ROMs that were very likely bit-rotted.
      Added some missing makefile dependencies [Atari Ace]
      Allow the non-DRC RSP core to build again (controlled by a #define
      like the SH-2 core) [Atari Ace]
      segas16b.c: Corrected the rom names for the FD1094 317-0120 Golden Axe
      set and verified the dump as good. [Brian Troha]
      lr35902.c: Added the speed register to the register list to allow it
      to be changed and retrieved again. [Sandro Ronco]
      converted mb3773 from a legacy device to a c++ device. tidied up
      comments in at28c16 [smf]
      djboy.c: Added unverified Beast MCU internal ROM image
      [Dr Decapitator, Tomasz Slanina, Lord Nightmare, Phil Bennett]
      sfbonus.c: Added the Amcoe "Classic Edition Compact Format" PCB
      layout. [Brian Troha]
      Added TMS32015 and TMS32016 CPU variants to the TMS32010 core. Fixed
      LST instruction which was sometimes adjusting internal RAM banking
      incorrectly. [Quench]
      Added Ameri Darts internal DSP dump and TMS32015 support to the
      Amerdart driver. Also added savestate support to the game.
      [Dr Decapitator, Quench]
      RSP: Fix sign issue in VCL opcode [angrylion]
      Puzzle Break [David Haywood, Smitdogg, The Dumping Union]
      New clones added
      Mystic Riders (bootleg?) [David Raingeard]
      Magical Odds (set 2) [W. Herve, Smitdogg, The Dumping Union]
      Raiden Fighters Jet - 2000 (China) [Brian Troha, Guru]
      Wonder Boy III - Monster Lair (set 6, System 16A, FD1089A 317-xxxx) (better dump?)
      [Team Europe]
      Street Fighter Zero (Hispanic 950718)
      [Layne, N. Francfort, R. Mucciarelli, Smitdogg, The Dumping Union]
      Captain Commando (World 911202) [Stefan Lindberg, The Dumping Union]
      Space Ship [f4brice]
      Juuouki (set 5, Japan, FD1094 317-0069, not working)
      Wild Fang [Stefan Lindberg, The Dumping Union]
      Fruit Bonus '06 - 10th anniversary (Version 1.3R CGA)
      [Brian Troha, The Dumping Union]
      Terminator 2 - Judgment Day (rev LA4 08/03/92)
      [Gor, Smitdogg, The Dumping Union]
      Gundam Battle Operating Simulator (GDX-0013)
      [Team Europe, Joerg Hartenberger]
      Sega Club Golf 2006 Next Tours (Rev A) (GDX-0018A)
      Ollie King (GDX-0007) [Team Europe, Joerg Hartenberger]
      Tokio/Scramble Formation (japanese?, newer)
      [Guru, Roger Coltrane, Smitdogg, The Dumping Union]
