Configur MESS with Snes9x or Zsnesw
  • Hi Guys...
    I'm new in this forum... I found it in the links section of Mala FE Website...
    This is my question:
    I'm building a console cabinet interfaced with Mala, with all the classic console games! or better, not all, just NES SMS Genesis and Super Nintendo!
    So this is my problem:
    I chose to use snes9x as emulator for snes games in Mala, but there's a problem, when I click esc to exit game and return to the FE menu the emulator don't colse!
    Just the upper menu appear and if I tap esc again the menu appear again and so on...
    But I would like that if I tap esc button the emuletor shut down and I return to the Mala game list.
    I tried also with Zsnesw but it is practically the same...
    I would like use MESS to emulate SNES, with it I would have such problem, but I have some problems with several games! some not works, and others works not very well, so I decided ti use other emulator as Snes9x or Zsnesw
    How can I do!?!?
    Thank you for your attention!
  • Hi,
    try to use Malas Hotkey function.
    "ESC ---> ALT + F4"
    The Emulator should close without problems then.
  • THANK YOUUUUU!!!!! you are great!!! can't belive it!!!...
    Do you think/know if there's some way to change the hotkey?
    I mean, when the cabint will be ready I will use just the pad to interface with Mala... so, can I attribute alt+F4 to a combination of button on the pad?
    Thank you again!
  • With this tool you can use your Joypad as a Keyboard, similar to JoyToKey but with many more functions. You can also use shortcuts like ALT+F4 on a single Joypad button.
    Maybe mala itself is capable of those functions without using Xpadder, but i am not shure about it.
  • Thank you very much guys!!! =)
    Yes I found a documentation about xpadder and I will also take a look on the forum you suggest me!...
    Another question guys...just to not open a new 3d...
    Do you know where I can find the artbox, snaps, and video stuff to complete my Mala layout...
    I mean artbox, snaps and video not for MAME but for SMS, Genesis, NES and Snes systems!
    Thank you again!!!
  • Hy guys...
    I check on the ArcadeControls.com forum and they suggest me this wich work great to exit Znes and return in Mala menu:
    Just open the Znes.cfg file with wordpad and change the line guioff=0 in guioff=1
    It works great!!!:D
    Thank you everibody...
    What about extrafiles???
