Mame 0.129u3
  • 0.129u3
    MAMETesters Bugs Fixed
    - 01017: [Sound] nslasher: The music stops at some points in the game
    when fighting bosses and some points in level 2. (Mamesick)
    - 02862: [Graphics] Many sets in taitosj.c: During the scroling the
    lower part of the screen becomes black (Aaron Giles)
    - 02860: [Crash/Freeze] mach3, usvsthem: Error at the start
    (Aaron Giles)
    - 02880: [Original Reference] stactics: Scratchpad RAM is too large
    (currently 2 KB, should be 256 bytes with mirroring).
    (chowell)
    - 02843: [Original Reference] schaser, schasrcv, polaris: Only half
    the color RAM is emulated. (chowell)
    - 02884: [Original Reference] kopunch: CPU is specified as a 4 MHz
    8080 when it should be a 4 MHz Z80. (Tomasz Slanina)
    - 02888: [Graphics] All sets in megaplay.c: Large black box obscuring
    game (Aaron Giles)
    - 02827: [Compiling] 64-bit build fails (Phil Bennett)
    - 02804: [Documentation] dkongf: In game information: year should be
    2004, not 1981. (Fabio Priuli)
    - 02803: [DIP/Input] dkongf: "5 Coins/1 Credit" coinage dipswitch is
    freeplay. (Fabio Priuli)
    - 02719: [DIP/Input] arkbloc2, arkgcbl, paddle2: you can't go to the
    left (Fabio Priuli)
    - 02697: [DIP/Input] hkagerou: Inputs apparently incorrectly mapped or
    not mapped (Fabio Priuli)
    - 02574: [DIP/Input] yumefuda: Game controls are not fully implemented
    (Fabio Priuli)
    - 02873: [Graphics] Many sets in system1.c: Missing text layer
    (David Haywood)
    - 02866: [Misc.] bublbobl and clones: Bubble Bobble vertical sync value
    seems slightly off (Phil Bennett)
    - 02792: [DIP/Input] Missing HARDDIP settings in 'STANDARD_DIPS' for
    DIP's 4,5 and 6 ("COMM Setting") (Fabio Priuli)
    Source Changes
    Cleaned up and remapped Big 10 inputs. Updated the game notes. Added
    other minor changes. [Roberto Fresca]
    Improved the sound in Double Wings by appling the same handling of
    Night Slashers (they are actually similar if not same memory map)
    [Angelo Salese]
    Fixed scrolling layer in Magic's 10 [Angelo Salese]
    Added NO_DUMP for the H8/330 MCU for Magic's 10 2, Super Pool, Hot
    Slot and Magic Colors. [Angelo Salese]
    Several discrete sound refinements, mainly targeted at mario:
    [couriersud]
    * Use formula derived from figures 2 and 3 in LS624 datasheet.
    Coefficients were calculated using least square approximation.
    This approach gives a bit better audible results compared to the
    prior approach.
    * Fixed energy calculation for LS624
    * Use energy values as input for XOR. This seems to better reflect
    the superimposition of the two signals. On the long term, both
    LS629 and the XOR need to be converted into a custom module to
    properly model mixing if the two frequencies are close to each
    other.
    * Adjusted C41 to 60% for skid sound.
    Fixed the remaining CPS3 sets that were left broken from the previous
    half-done set renames. Also reworked the code a bit to make it harder
    for somebody to break it in future (removed the config table & moved
    keys to driver inits, define region sizes, allocate memory in init
    for CD based games.) Should be no functional changes, although it
    might be a fraction of a % faster due to there being less region
    lookups. [David Haywood]
    Added preliminary sound for the Aero Fighters bootlegs (aerfboot &
    aerfboo2) [Angelo Salese]
    Added some 'new fruit bonus '96' sets, unsure what they are.
    [David Haywood]
    Added a mess of sets marked as 'time dog' to the goldstar driver.
    These seem to be mismatched, and some lack program roms. One set has
    encrypted code, the other appears to have plain code. These will need
    some tidy-up work. I've added them, because there is no doubt at
    least one valid set in here but the dumps contain no useful info at
    all. [David Haywood]
    Preliminary protection hook-up for Sexy Gal/Sweet Gal [Angelo Salese]
    Fixed colors, visible area and soft resets in the Magic Card 68k
    version. Started to convert the Magic Card 68k version driver with
    proper infos & added some basic video registers. It actually runs on
    more or less modified Philips CD-i architecture. [Angelo Salese]
    Imported Archimedes code from MESS. [R. Belmont]
    Fixed foreground tilemap colors in Diamond Derby [Angelo Salese]
    Added new module devcb, which can generically handle conversions
    between device read/write functions and various other types of
    functions. Introduced new structures and macros to make this possible:
    [Aaron Giles]
    To take advantage of this, a device must change its interface to
    replace any read/write callbacks with the new devcb_read/write
    structures. During device start time, the device then uses this new
    devcb module to resolve the information in the devcb_read/write
    structures into a more efficient form. When the device needs to call
    one of the callbacks, it uses the inline devcb_call_read/write
    functions.
    Once a device has defined its callbacks as devcb_read/write
    structures, users of the device must use the DEVCB_* macros to
    specify the type and information about the handler to use:
    DEVCB_NULL = no handler
    DEVCB_HANDLER = a standard device read/write handler
    DEVCB_MEMORY_HANDLER = a memory address space read/write handler
    DEVCB_DEVICE_HANDLER = a device read/write handler for a different
    device
    DEVCB_INPUT_PORT = an input port
    Converted the 8255PPI device to use this new structure, and updated all
    users to use the DEVCB macros, removing some unnecessary trampoline
    functions along the way. [Aaron Giles]
    Added calculation for caps >= 100pf to buck rogers LS626 frequency
    calculation. Formula was derived from figure 6 of LS624/628/629 &
    625/626/627 datasheet. "BUCK ROGERS" is now centered and big ship
    appears centered over br's ship. [couriersud, Guru]
    Converted 6821new device to use devcb. Updated Williams drivers to
    remove trampoline functions. [Nathan Woods]
    Improvements to norautp.c driver: [Roberto Fresca]
    - Merged GTI Poker (gtipoker.c) with this driver.
    - Added new memory map and machine driver for gtipoker.
    - Hooked 2x PPI 8255 to gtipoker.
    - Hooked the video RAM access ports to gtipoker.
    - Changed norautpn description from Noraut Poker (No Payout),
    to Noraut Poker (bootleg), since the game has payout system.
    - Some clean-ups.
    Fixed encryption in Cabaret and added sound emulation [Mirko Buffoni]
    - Moved to a separate driver
    - Not fully playable, press reset to exit from pitfalls
    Implemented a few more H8/3xx instructions, and added funcube to
    seta2.c [Luca Elia]
    Added a default backup ram for the jolyc980 set, to get it boot to
    the end-user. [Angelo Salese]
    Big 10 [Angelo Salese, Roberto Fresca, Tomasz Slanina]
    Bottle 10 (italian, 2 sets) [Roberto Fresca]
    Super Poker (v116IT) [Mirko Buffoni]
    Casino Five [Mariusz Wojcieszek]
    Big Apple Games [Mariusz Wojcieszek]
    Funcube 2 [Luca Elia]
    Funcube 4 [Luca Elia]
    New clones added
    Turbo Sub (prototype rev. TSC7) [Jay Gallagher]
    Noboranka (Japan) (NOT WORKING, undumped 8751 MCU)
    Battle Bakraid - Unlimited Version (U.S.A.) [Josh W.]
    Armed Police Batrider (several versions) [Josh W.]
    Mortal Kombat (prototype, rev 8.0 07/21/92) [Brian Troha]
    Jansou
    Noraut Poker [Roberto Fresca, Angelo Salese]
