Mame 0.129u2
  • 0.129u2
    MAMETesters Bugs Fixed
    - 02810: [DIP/Input] hanaroku,hanaawas: Input keys are
    inconsistent with other hanafuda games [Sonikos]
    - 02852: [Known Issues/To-Do's] cloak and clones: Message "SLAVE
    COM BAD" flashes before game startup (Phil Bennett)
    - 02847: [Crash/Freeze] all cloak.c and midzeus.c sets: [debug]
    Access Violation (Phil Bennett)
    - 02842: [Graphics] logger: gfx issue (Aaron Giles)
    Source Changes
    Fixed compilation errors if HAS_SAMPLES is 0. [Nathan Woods]
    Stop crash/assert when trying to decrease the debugger memory window
    bytes per line to 0. [Phil Bennett]
    Improved implementations for undocumented instructions 63, 67, 6f, 73,
    77, 7b, 7f, 9c, 9e, ab, e3, e7, ef, f3, f7, fb, and ff in the n2a3
    cpu core. [Wilbert Pol]
    Force recalculation of screen parameters when only the MC6845 input
    clock changes. [Wilbert Pol]
    Seibu CRTC part 1: [Angelo Salese]
    * Merged Sengoku Mahjong & Good e Jong video HWs
    * Added correct scrolling functions for Sengoku Mahjong
    * Removed some positioning kludges in both drivers
    Fixed Sengoku Mahjong hopper error after first winning match.
    [Angelo Salese]
    Removed deprecat dependancy from Good e Jong, one irq wasn't needed
    at all (points to a reti). [Angelo Salese]
    Fixed cpu reset for upd78c06. [Wilbert Pol]
    Added new #define ENDIANNESS_NATIVE, which maps to either
    ENDIANNESS_LITTLE or ENDIANNESS_BIG based on the LSB_FIRST definition.
    Unlink LSB_FIRST, ENDIANNESS_NATIVE always exists and can be used in
    expressions without invoking the preprocessor. [Aaron Giles]
    Added macro ENDIAN_VALUE_LE_BE() which selects one of two values based
    on the endianness passed in. Also added NATIVE_ENDIAN_VALUE_LE_BE()
    which calls ENDIAN_VALUE_LE_BE with ENDIANNESS_NATIVE. [Aaron Giles]
    Updated a number of drivers and call sites to use these macros in
    favor of #ifdef LSB_FIRST. [Aaron Giles]
    Removed some stray ADDR2BYTE/BYTE2ADDR macros that have been replaced
    by inline functions. [Aaron Giles]
    DRC frontends must now do their own opcode fetching unfortunately.
    Updated all DRC cores to do this. Also tweaked a few oddities in the
    SH2 DRC. [Aaron Giles]
    drw80pkr changes: [Jim Stolis]
    - Added bankswitching to program memory
    - Partial graphics support
    - Partial sound support
    Preliminary ADPCM hook-up to Jantotsu, it plays something but it's
    not yet right. [Angelo Salese]
    Removed redundant config parameter from SND_START. [Aaron Giles]
    Fixed gfx regression with 18 Holes Pro Golf and added proper memory
    map for the second cpu. [Angelo Salese]
    Sound cores no longer allocate their own tokens. Instead they return
    a new integer value indicating the size of token they want, and the
    core allocates it for them. This mirrors the standard device behavior.
    [Aaron Giles]
    SRMP5 update [tsBTN0640]
    - sound pitch is low with current st0016 driver.
    Fixed Perfect Soldiers input (added missing button3) [a3SEybxT0]
    Added missing key for sfiiij and sfiii2j [swzp1Dp/0]
    Tidied up the micro3d driver and fixed sound. [Phil Bennett]
    Increased Cloak & Dagger interleave quantum to eliminate 'SLAVE COM
    BAD' startup message. [Phil Bennett]
    Major cleanup to IGS poker games [Mirko Buffoni]
    - Renamed csk driver to igspoker. This includes Champion Poker,
    Champion Skill, New Champion Skill
    - Converted drivers to tilemap system and unified video section
    - Unified memory maps and checked all input ports
    - Removed obsolete palette handlers and made use of generic handlers
    - Added layout for lamps handling
    - Added hopper simulation
    - Added New Champion Skill (different set, maybe original
    international release) and renamed current igs_ncs to igs_ncs2
    (2000 version for italian market)
    - Promoted igs_ncs2 to working state, but set GAME_IMPERFECT_GRAPHICS
    (missing initial notice screen)
    - Moved Jackie to a separate driver (it's a slot machine game)
    - Made some progress on Jackie which now boots (toggle mode to play,
    but work still needs to be done)
    Virtual Combat and Shadow Fighters update. [Phil Bennett]
    * Fixed framebuffer handling & screen parameters.
    * Added sound.
    * Corrected RAM sizes to match what is present on the PCBs.
    * Hooked up NVRAM.
    Fixed clamping to 12 bit range to Okim6376, and adjusted volume
    attenuation accordingly. [Mirko Buffoni]
    Fixed TMS5220 speech in Turbo Sub [Phil Bennett, Jay Gallagher]
    adp improvements: [robiza]
    - implemented p1 inputs in skattv and fashiong (service mode is
    working)
    Defined ROM_LOAD64_WORD/ROM_LOAD64_WORD_SWAP in emu/romload.h.
    [Phil Bennett]
    cb2001: mapped two more opcodes. [robiza]
    Fixed Soul Calibur (vs. Inferno) [4oj9/xJ+0]
    Added custom 3-screen layout to Stepping Stage driver. [Naibo Zhang]
    Changed yunsung8 oki xtal to 400khz, verified on pcb. Unfortunately
    I couldn't verify the main xtal which was missing on my pcb.
    [Corrado Tomaselli]
    Restored previous cycle eating behavior in gstream. [Mamesick]
    Changed device start routines to no longer return a status. Instead,
    if a device needs to delay its initialization pending the startup
    of another device, it must call the new function device_delay_init().
    [Olivier Galibert]
    Give us a Break (2 sets) [Phil Bennett]
    Ten Up (2 sets) [Phil Bennett]
    Himeshikibu (Japan) [Uki]
    Super Othello [Tomasz Slanina]
    New clones added
    Cannon Ball (Yun Sung) (vertical) [David Haywood]
    Sega Water Ski (Japan, Revision A) [Smitdogg Jones]
    Raiden Fighters 2 (USA, SPI) [Arzeno Fabrice]
    Stepping 3 Surperior [Naibo Zhang]
