0.128u6
MAMETesters Bugs Fixed
- 02728: [Crash/Freeze] galpani3: 'Illegal Instruction' after ROM Check
(R. Belmont)
- 02739: [Sound] skysoldr: In-game music (three level BGMs and boss theme)
plays one octave higher. (Phil Bennett)
- 02718: [Crash/Freeze] zigzag, zigzag2: Don't boot correctly. The screen
just flashes over and over. (Aaron Giles)
- 02730: [Crash/Freeze] fiveside: locks up at rom check (Aaron Giles)
- 02740: [Debugger] resizing the debug window, the text is only in the
old area (Aaron Giles)
- 02721: [Crash/Freeze] All Sets in arcadia.c: Games not booting, they
just keep resetting to a white screen. (Aaron Giles)
- 02661: [Gameplay] f1gpstr2: Game freezes upon reaching track (Mamesick)
- 02708: [Crash/Freeze] wildplt: Gameplay freezes at start (Mamesick)
- 02724: [DIP/Input] elgrande, jjpoker, ssipkr24: Unable to locate input
port 'SW2'. (Roberto Fresca)
- 02677: [Graphics] eprom, eprom2: missing graphical brightness effect,
verified on real machine w/video (Nicola Salmoria)
Source Changes
Pointer-ified the following CPU cores:
- DSP32 [Aaron Giles]
- m6805 [Andrew Gardner]
- MIPS 3 [Aaron Giles]
- PowerPC [Aaron Giles]
- Konami [Aaron Giles]
- ARM [Andrew Gardner]
- SHARC [Atari Ace]
- V60 [Aaron Giles]
- Z8000 [Aaron Giles]
- Z180 [Aaron Giles]
- V810 [Aaron Giles]
- V30MZ [Aaron Giles]
- PDP1/TX0 [Wilbert Pol]
- H6280 [Andrew Gardner]
- F8 [Atari Ace]
- TLCS-90 [Atari Ace]
- Cube Quest CPUs [Aaron Giles]
- i86/i286 [Aaron Giles]
- i386 [Aaron Giles]
- ALPHA-8201 [Aaron Giles]
- i8085 [Aaron Giles]
- APEXC [Aaron Giles]
- RSP [Aaron Giles]
- MB88 [Aaron Giles]
- MB86233 [Aaron Giles]
- TMS7000 [Aaron Giles]
- SH2 [Aaron Giles]
- SH4 [Aaron Giles]
- uPD7810 [Aaron Giles]
- TMS32051 [Aaron Giles]
- MC68HC11 [Aaron Giles]
- CP1610 [Aaron Giles]
- LH5801 [Aaron Giles]
- LR35902 [Aaron Giles]
- PDP1 [Aaron Giles]
- Saturn [Aaron Giles]
- SC61860 [Aaron Giles]
- TMS32010 [Quench]
- PIC16C5x [Quench]
- TMS99xx [Aaron Giles]
- TMS32025 [Quench]
- dsp56k [Quench]
Enabled all CPU cores/variants. Fixed compile issue revealed as a
result. [Aaron Giles]
Changed konami setlines callback to pass a device. Updated all drivers
accordingly. [Aaron Giles, Atari Ace]
Added best-known CRC in wb90b2 and jjsquawb "bad dump" roms. [robiza]
Made the PCI bus a device. The bus is declared in the machine config,
and the devices attached to it are enumerated there. Eventually, the
PCI config read/write functions should be moved to well-known
functions within the device, but for now they are kept separate.
[Aaron Giles]
Added correct proms for arkgcbl. [robiza]
Changed many, many global Machine references to use machine,
device->machine, etc. instead. [Atari Ace]
Changed megadriv.c to pass running_machine to I/O callbacks plus other
MESS support. [R. Belmont]
Re-synced f3853 core with MESS. [Nathan Woods]
Introduced function macros for SAMPLES_START, CUSTOM_{START,STOP,RESET},
and ANTIC_RENDERER. Pushed the running_machine * passing through these
functions. In other locations added "running_machine *machine = Machine"
to the top of functions to isolate the dependencies. [Atari Ace]
Added logic to track OSD debugger updates separately from internal
view updates. In order to get the OSD to update, a new function
debug_view_flush_updates() must be called. Currently this is
automatically called before osd_wait_for_debugger(), and during the
periodic updates while executing. The OSD code may occasionally need
to call it under other circumstances (for example, the Windows code
calls it explicitly while tracking scrollbar thumbs to get live
scrolling). [Aaron Giles]
Updated gradius2 to use proper gfx2 roms (same values of vulcan but
byteswapped). [robiza]
Disabled the use of PULSE_LINE for any input lines except NMI and
RESET. Added a helper function generic_pulse_irq_line() for doing a
single-cycle assert/deassert for those few drivers remaining that were
trying to use PULSE_LINE directly. [Aaron Giles]
Updated z8000 tables to reflect recent findings. [Juergen Buchmueller]
Fixed the widely used konamiic/taitoic/deco16ic/segaic16 video cores
to no longer reference the global Machine. [Atari Ace]
Added wrappers for ADSP21xx callbacks. Added device parameters to them.
Updated IRQ setters to use generic_pulse_irq_line(). [Aaron Giles]
Added MDRV_PIC8259_ADD, MDRV_PIT8353_ADD, MDRV_PIT8254_ADD, and
MDRV_DMA8237_ADD macros. [Wilbert Pol]
Added the sound device to the parameters passed to stream_create so
that the global Machine can be removed from streams.c. [Atari Ace]
Improvements to Millennium 4000 driver: [Roberto Fresca]
- Completed normal Inputs/Outputs.
- Added button-lamps calculation.
- Created button-lamps layout.
- Documented the PCB RAM.
- Fixed NVRAM size based on PCB picture (2x CY62256L-70PC near the
battery).
- Added notes about the method to make appear the real poker cards.
- Fixed the OKI 6295 frequency (1000 kHz resonator near). Now the
game has more decent sounds.
- Corrected CPU clock to 12 MHz. (main Xtal).
Updated adp driver: now fashiong show something. [robiza]
Widened some machine init interfaces to pass the machine parameter,
allowing more Machine global references to be eliminated. Eventually
most of these need to be converted to devices, but this change reduces
the deprecation surface in the meantime. [Atari Ace]
Relaxed the OKI 6295 command validity check. [Nicola Salmoria]
Added new function cpuexec_describe_context(machine) which can be
used in logerror() and other printf-style functions to return a
description of the current CPU/PC given only the machine. Changed
several dozen sites to use this instead of directly interrogating
the activecpu. [Aaron Giles]
Removed all other uses of activecpu throughout the system. Removed
activecpu from the machine structure to prevent future abuse.
[Aaron Giles]
Removed cpu_push_context() and cpu_pop_context(), and all call
sites. [Aaron Giles]
Voodoo devices now require a CPU to be defined in the configuration
in order to know whom to steal cycles from or stall when FIFOs get
full. Updated all voodoo users to specify one. [Aaron Giles]
CPD1869 devices now also require a CPU to be defined in the
configuration, in order to know which CPU's registers to fetch.
Updated all cdp1869 users to specify one. [Aaron Giles]
Removed get context/set context calls from the CPU interface entirely.
[Aaron Giles]
Removed safe_cpu_get_pc() which doesn't really make sense anymore.
[Aaron Giles]
Moved cpu_execute() to be an inline function. [Aaron Giles]
Writes to a pit8253 timer control word always restart the timer.
[Wilbert Pol]
Updated the fcompress APIs to allow for specifying a compression level.
[Aaron Giles]
Removed the concept of state saving tags, which was a hack to get save
states to work with multiple CPU cores. Simplified the state saving
system as a result, performing the operation in a single pass and
without allocating a full blob of memory. Also enabled minimal
compression. [Aaron Giles]
Squashed another deprecated use of Machine from the mame core by
plumbing machine_config into rendlay.c. [Atari Ace]
Fix Altivec RGB primitives on newer GCCs. [budge, Vas Crabb]
Changed commonly-used verboselog to require a machine parameter.
[Atari Ace]
Removed remaining deprecat.h references from the CPU and sound cores.
[Atari Ace]
i8085: added INTE and state word callbacks [Curt Coder]
n8080.c changes: [Curt Coder]
- rewrote interrupt handling according to schematics
- added interrupt acknowledge
Re-ordered SCSP init to fix crash. [R. Belmont]
Modified regrep to display the soruce file. [Aaron Giles]
Expanded cpuexec cycles <-> attotime functions to handle UINT64s.
[Aaron Giles]
Reduced all alpha68k.c YM2413 clocks from 8MHz to 3.579545MHz.
[Philip Bennett]
Changed attotime_to_ticks/ticks_to_attotime to use UINTs and the
eminline functions where possible. [Aaron Giles]
Changed the 6522 VIA implementation to be a device. [Nathan Woods]
Removed the ACIA6850 device from Cal Omega System 905 machine driver.
It fixes the wrong lack of SW2. [Roberto Fresca]
Fixed EI handling in the 8080/85 core to have a shadow like the Z80.
[Miodrag Milanovic]
Modified the tms34010.h, pc16552.h, and tms34061.h interfaces to
eliminate some more global Machine variables. Six more deprecat.h
includes eliminated. [Atari Ace]
Eliminated the #include "deprecat.h" from tilemap.c. The main change
is to require callers of tilemap_create to provide a machine pointer.
This pointer is then attached to the tilemap and used when needed
inside tilemap.c. [Atari Ace]
Eliminated the #include "deprecat.h" from drawgfx.h. It does so in a
fashion similar to my recent tilemap patch, adding the machine pointer
to gfx_element, changing allocgfx to take a machine, and then
adjusting the internals to use the machine field as needed.
[Atari Ace]
i960: fixed nor opcode and added notor opcode [robiza]
Fixed raster effects in nbbatman by altering the V33 prefetch timing
(just a guess as no documentation has been found). [couriersud]
Removed unnecessary address masking in disassembly view. Changed
console subview computations to leave the registers portion fixed.
[Aaron Giles]
Removed hack for setting mcs51 serial callbacks. Updated micro3d to
use new functions. [Aaron Giles]
Merged goldstar.c & cmaster.c drivers. Converted the Reels video to
tilemaps. [David Haywood]
Added proper artwork for the LEDs in Gridiron Fight. [David Haywood]
Super Pool 99 [David Haywood, Angelo Salese]
Bra$il / Fashion [Angelo Salese]
Pesadelo [Mariusz Wojcieszek, hap]
Super Free Kick [Tomasz Slanina]
Jangou [David Haywood, Angelo Salese, Phil Bennett]
Jangou Lady [David Haywood, Angelo Salese, Phil Bennett]
New clones added
Europa 2002 Space (Ver 3.0) [Roberto Fresca]
Triv Two (Vertical) [David Haywood]
Super High Impact (prototype, rev 6.0 09/23/91) [Smittdogg]
Giga Man 2: The Power Fighters [David Haywood, Arzeno Fabrice]
CarnEvil (v1.0.3) [Brian Troha]
(New?) Cherry Bonus III (not working) [David Haywood]
Cherry Bonus 2001 [David Haywood, robiza]
Four Roses (encrypted, 2 sets) [Roberto Fresca]
Queen [David Haywood]
Cherry Master (Corsica, v8.01) [David Haywood]
Cherry Master 91? [David Haywood]
Jackie [David Haywood]
