Mame 0.128u3
  • 0.128u3
    MAMETesters Bugs Fixed
    - 02633: [Crash/Freeze] Many sets using the MC6845: Crash/hanging in
    many games. (Curt Coder)
    - 02626: [DIP/Input] crimfgt2, crimfgtj: Cannot start a game
    (Fabio Priuli)
    - 02618: [Sound] samuraia and clones: No SFX sound
    (Pierpaolo Prazzoli)
    - 02544: [Core] Dip Condition / Port Include limitation (Aaron Giles)
    - 02542: [DIP/Input] ghoulsu: Doesn't remove the original port when
    replacing it with a conditional port (Aaron Giles)
    - 02607: [Crash/Freeze] frogs: Taking a screenshot in Frogs (Gremlin) exits the game with an error. (aaron)
    Source Changes
    Changed 74123 into a device. Clarified behavior from datasheet. Added
    logic to avoid recursive calls. [couriersud]
    Fixed Dip Switches for all games in halleys.c driver.
    Added Dip locations for 'halleys' and clones. [stephh]
    More improvements to the 32x code. [David Haywood]
    Irem M10: first results from schematics: [couriersud]
    * Updated video timing and cpu/pixel clocks
    * Rewrote irq for m10/m11 to use two 74LS123
    AICA: fix missing instruments in DTPK driver games.
    [R. Belmont, Deunan Knute, kingshriek]
    Naomi: unmapped words in the AICA address range must read as zero.
    [R. Belmont]
    Corrected YM2203 balance in powerins. [Jim Hernandez]
    Converted toobin to RGB32 to allow for mid-screen palette updates.
    Also added correct video timing and full memory map, and connected
    watchdog. [Aaron Giles]
    Added Dip locations for 'exprraid' and clones, and for 'gyruss' and
    clones. [stephh]
    Hooked up 6845 to peplus driver: [couriersud]
    * Hooked up 6845 in a daisy chain way into existing "6845 emulation"
    * Clocks from schematics
    * Video size issues - 6845 code related, discussion started on list
    Re-inlined core attotime functions. This makes a significant
    difference when running with high interleaves. [Aaron Giles]
    Added support for recently-discovered internal Z80 register to the
    Z80 core. Improves accuracy of undefined flags. [Miodrag Milanovic]
    Reverted MC6845 changes as they broke a number of things. [Curt Coder]
    Converted Z80, R3000, ADSP2100, and M680x0 cores to reference their
    data via pointers instead of global structs, in anticipation of
    future changes. [Aaron Giles]
    Fixed coinage in Speed Attack! and cleaned-up the driver to current
    standards. [Angelo Salese]
    Converted the MCS-48, MCS-51, and m6502 cores to reference data via
    pointers. [couriersud]
    Added concept of scheduling quanta to the timer system. Also added
    means of setting the minimum useful scheduling quantum, and clamping
    all quanta to that value. [Aaron Giles]
    Changed interleave/boost handling to use scheduling quanta instead
    of timers. [Aaron Giles]
    Added machine parameter to cpu_boost_interleave. [Aaron Giles]
    Updated cpuexec to compute the "perfect" interleave value taking into
    account the minimum number of cycles per instruction specified by the
    CPU core. Updated Z80 core to indicate that the minimum cpi is 2.
    Fixed incorrect minimum cpi in the 68020+ cores. [Aaron Giles]
    Changed core cycle computations to use div_64x32 instead of full
    64-bit divides. This involves tossing a few bits of resolution at
    divide time, but should make no real difference in practice.
    [Aaron Giles]
    Began the process of pruning options from the 68000 core, hard-coding
    it for MAME's needs. We've hacked on it sufficiently that it is no
    longer generic, so this is a good opportunity to simplify the code
    so that it can actually be followed (still in progress). [Aaron Giles]
    Defined macros for all core CPU functions, along with macros for the
    name and for calling, in the spirit of the devintrf.h macros.
    [Aaron Giles]
    Changed init, reset, exit, and execute interfaces to be passed a
    const device_config * object. This is a fake object for the moment,
    but encapsulates the machine pointer and token. Eventually this will
    be a real device. [Aaron Giles]
    Changed the CPU IRQ callbacks to a proper type, and added a device
    parameter to them. [Aaron Giles]
    Fixed background color of srmp1/srmp2. [EdxGROfS0]
    Various improvements in the ST-V driver: [Angelo Salese]
    * Fixed bitmap zooming in Virtual Mahjong 2 - My Fair Lady;
    * Worked around a major graphic bug in ElanDoree;
    * Added some missing alpha blending effects,Pro Mahjong Kiwame S
    title screen needs it but it doesn't work yet due to other
    problems (still investigating)
    * Fixed a crash bug with Astra Super Stars when the debugger is
    active.
    Merged DS5002FP into MCS51: [couriersud]
    * Merged DS5002FP
    * Disassembler now uses type specific memory names
    * Merged DS5002FP disasm
    * added 83C751 memory names to disassembler
    * delete DS5002FP specific files
    * removed unnecessary cpu callback in wrally
    * DATA_MAP ==> IO_MAP in wrally
    Continued rewrite of the Motorola DSP56k CPU core:
    [Andrew Gardner, PhilB, RBelmont]
    * Added proper clock speed to plygonet.c and internal divider to
    dsp56k.c
    * Fixed up disassembler add/sub, 05xx, and bsr ops.
    * Handle mysterious uuuuF instruction found in plygonet add op.
    * Partially implemented add, sub, mac, mpy, inc, cmpm, macr, asr16,
    jscc, lea, and movec ops.
    * Added dual X memory read and data move with short displacement
    parallel moves.
    Some improvements to the Forte Card driver, not yet working.
    [Angelo Salese]
    Changed Psicho Nics Oscar (japan revision 0) to (world revision 0)
    since there is no japan disclaimer. [Corrado Tomaselli]
    Fixed missing inputs in expro02. [Sonikos]
    CPS2 ROM updates to match PCB labels. [Razoola]
    Added ADDRESS_MAP_NAME macro, updated CPU cores to use it to reference
    internal address maps. [Atari Ace]
    Added include files for many drivers that never bothered before.
    [Atari Ace]
    Improved Star Castle drone sound. [Jim Hernandez]
    Snezhnaja Koroleva [Antro]
