MAME 0.128u1
  • 0.128u1
    MAMETesters Bugs Fixed
    - 01722: [Crash/Freeze] sokonuke: Game hangs after you choose stage.
    (Aaron Giles)
    - 00468: [DIP/Input] gogomile, gogomilj: Inserting coins or pressing
    start has no effect at the continue screen. (Phil Bennett)
    - 00436: [Sound] kyukaidk: Some of sound effects are wrong. Umpire's
    voice is most notable. Also, music is not correct.
    (Phil Bennett)
    - 01702: [Gameplay] cloak + clones: Can´t pick up items (Phil Bennett)
    - 02140: [Save/Restore] cubeqst: cube quest crashes mame when saving
    state (Phil Bennett)
    - 02577: [DIP/Input] crush and clones: Broken Dips (Fabio Priuli)
    - 00359: [Sound] blocken: Some of the enemy voices are totally wrong
    (Phil Bennett)
    Source Changes
    MC6845 changes: [Curt Coder]
    - added cursor and display enable skewing
    - added preliminary support for SY6545-1's transparent addressing mode
    - Hsync should be pulsed even when vsync is active.
    Removed per-game hacks from CPS3 (moved to DMA callback in SH2 core).
    Removed Speedups from CPS3 / PsikyoSH, while they do still give a
    decent speed boost they're not really needed with the DRC and just
    clutter the code. [David Haywood]
    Minor NeoGeo cleanups [JohnBoy]
    Rewrite of the Motorola DSP56k CPU core. [Andrew Gardner]
    * Complete rewrite focusing on legibility and extensibility.
    * 27/121 opcodes (mostly) implemented.
    * Bugfix for reset status of interrupt priority bits.
    * Bugfix for disassembly of register-to-register parallel data move.
    * Added additional branch, move and bitfield ops.
    * Plygonet now passes its memory test and uploads a new program.
    * Implemented tst, or, jsr, rti, tst2, and 2 new movec ops.
    * Added opbase handler to plygonet.c
    Increase cubeqst interleave factor to eliminate LDP timeout countdown
    flicker. [Philip Bennett]
    Added redumped B-Rap Boys sample ROMs. [Guru]
    Cleaned up STV rom loading a bit. [David Haywood]
    NamcoNBx: fixed C75 BIOS loading for big-endian targets. [R. Belmont]
    Updated tnzs.c driver: [stephh]
    - renamed sets :
    * 'tnzsjn' -> 'tnzsj'
    * 'tnzsj' -> 'tnzsjo'
    * 'kagekia' -> 'kagekih'
    - fixed Dip Switches for all games (2 remaining unknown Dips in
    'plumppop' and 'jpopnics' though)
    - added many notes
    Small cleanups to the ST-V driver. Make some work for magzun, still
    not working. [Angelo Salese]
    AICA: fix sample addressing for the full 8 MB [kingshriek].
    Fixed bnstars1 screens. [David Haywood]
    MCS51/I8051 overhaul, micro3d improvements and full m72 protection
    emulation for lohtb2: [couriersud, Jim Stolis]
    * improved serial port timing
    * better infrastructure for adding more variants like DS5002
    * Fixed port reading
    * Rewrote Macros for better readibility
    * Fixed and rewrote Interrupt handling
    * Now returns INTERNAL_DIVIDER, adjusted cycle counts
    * Remove unnecessary and duplicated code
    * Remove unnecessary functions
    * Rewrite to have sfr-registers stored in int_ram.
    * Debugger may now watch sfr-registers as well.
    * implemented interrupt callbacks (HOLD_LINE now supported)
    * Runtime switch for processor type - remove ifdefs
    * internal memory maps for internal rom versions (internal ram now
    displayed in debugger)
    * more timer cleanups from manual
    * fix timer 2 interrupts
    * implement serial mode 2/3 rx and tx clock handling
    * Remaining games checked and adapted to changes in cpu core
    * Cardline still broken. I need the exact and complete cpu name.
    * Added more variants 803X, 80CXX, AT89C4051
    * Fix segas18.c (segaic16.c) mcu maps.
    * Fix sslam.c
    * Fix limenko.c videopkr.c : Issue with core allocation of ram (duplicate savestate)
    micro3d improvements: [couriersud]
    * serial port communication between main cpu and sound board works
    * sound board now works
    m72 - lohtb2 improvements: [couriersud]
    * full emulation of protection device
    * Samples are now piped through the mcu
    Added sound and corrected wrong DIP-SW in the Double Dealer driver.
    Completed protection vectors, fixed video emulation and added coin
    setting simulation. [Angelo Salese]
    Fixed recently regressed raster interrupt issues in fuukifg*
    drivers. [Philip Bennett]
    Added flip screen / cocktail support to yumefude driver. Completed
    DIP-Switches (manual-wise) and made better comments. [Angelo Salese]
    Separated umk3 and breakrev from their parents. [David Haywood]
    Some reorganization in megadriv.c, porting over some code to attempt
    to get it working again, bit by bit. [David Haywood]
    Improved dakkochn gfx; the priority are ok but there are various
    offset so i marked also the game as "inperfect gfx". [Sonikos]
    Fixed a subtle bug in the 65c02 emulation where the result of the BIT
    instruction differs on the 65c02 (from the 6502), when executed
    in immediate mode. [Phill Harvey-Smith]
    Added samples suppor to Cosmic Alien. [T. Bellm]
    (Medal) Yumefuda [Bet] [Angelo Salese]
    Grudge Match (Yankee Game Technology) [Aaron Giles]
    Double Dealer [Angelo Salese, David Haywood]
    Super Megatouch IV (9255-41-07 ROG, New Jersey version)
    [Mariusz Wojcieszek]
    Mirage Youjuu Mahjongden [Angelo Salese]
    New clones added
    The King of Fighters 2002 (bootleg) [Kawaks]
    Police Trainer (v1.3B Newer) [Brian Troha]
    Egg Venture (Release 8) [Brian Troha]
    Kick for the Goal [Brian Troha] (Not Working)
    Fire Shark (Korea, set 1, easier) [Guru]
    Fire Shark (Korea, set 2, harder) [Guru]
    Seibu Cup Soccer (set 2) [Chris Hardy] (NOT WORKING)
    P's Attack [Guru]
    Magic the Gathering: Armageddon [David Haywood]
