Hi
Es ist mal wieder eine neue Version von Coin Ops in der mache !
Es sollen wieder einmal einige Games dazu kommen, plus einige
fixes was den Systemkern angeht.
Hier erst mal die geplanten Features !
OPTIONS EXCEPTED SO FAR
- New games added
- Junk Games Removed
- Get size to under 4.5G (STILL IN PROGRESS plus extra fullset installer later)
- X Sort by Name ( If "Extra Keys Change Sort Method" is Enabled )
- Y Sort by Type ( If "Extra Keys Change Sort Method" is Enabled )
- B Sort by Manufacturer ( If "Extra Keys Change Sort Method" is Enabled )
- Fixed all issues from spreadsheet (STILL IN PROGRESS)
- SMB Fixed and all files compliant
- Rego over all screenshot and cat to improve the quality
OPTIONS REJECTED SO FAR
- 720p causes alot of issues with larger games and would require a new vmm.txt and also alot of games dont work. With very little reward
OPTIONS I WILL WORK ON TRYING TO GET IN
- Get Commandline launching working properly and docummented.
- Get SMB fully documented.
- Look at New games to add.
- Change cheats menu around a bit.
- Look at the best way to handle a new autofire option
- Look at the best way to handle 2 player game switching
- Fix speed in double dragon 1 and 2
- Add sound to Midway games
-Quelle- 1Emulation.com
MAD01.
