0.122u3
MAMETesters Bugs Fixed
hstennis0103u2gra [Brian Troha]
edrandy0113gra [Brian Troha]
robocop2_0106u3gra [Brian Troha, Bryan McPhail]
mario0110u1gre [couriersud]
sbrkout0118yel [R. Belmont, Adam Bousley]
pestplce0122red [couriersud]
funkyjet055yel [Bryan McPhail]
liberate074u1gre [Bryan McPhail]
tokiu056gre [Bryan McPhail]
powerbls0112u4red [Pierpaolo Prazzoli]
wwestern0115u1yel [Atari Ace]
namcos1_0118u2yel [Atari Ace]
victnine0116u2red [Pierpaolo Prazzoli]
btoads0103gre [Aaron Giles]
Source Changes
Fixes clocks for Orbs. [David Haywood, Tomasz Slanina]
Fixed various 64-bit GCC warnings. [R. Belmont]
Improves accuracy and documentation of NSS/SNES DSP-1.
[Andreas Naive, R. Belmont]
Added new file xtal.h, documenting all known arcade PCB clock cystals.
Drivers should be updated to use these as a basis for their clocks,
and the list should be augmented as additional crystals are found.
[Guru, Aaron Giles]
suprloco improvements: [Pierpaolo Prazzoli]
* Fixed IC.34 memory test
* Fixed 2nd player cocktail mode
* Changed coin3 to service1
Cleaned up inputs/DIP switches in cninja driver. [Brian Troha]
Rewrote mario.c: [couriersud]
- rewrote driver, separate MACHINE_DRIVER(mario_audio)
- palette from schematics
- video timing from schematics
- driver configuration switch Nintendo/Std Monitor
- got rid of COLORTABLE
Fixed typo for IO1 irq callback in hyperstone core.
Added memory_get_bank() function. Fixed logging in memory.c to to use
%p for pointer values. [Aaron Giles]
Fixed save states in i8051 cpu core [Pierpaolo Prazzoli]
Implemented a few SysCtrl, Maple, and PVR/HOLLY bits for Naomi. The
BIOS gets slightly further but is nowhere near starting up.
[R. Belmont]
Zeus updates: [Aaron Giles]
* Better documented various bit latches.
* Hooked up crusnexo lamp board (added layout).
* Fixed year in MK4 startup test.
Fixed TMS5110 tables. [couriersud, Lord Nightmare]
Removed ui_popup(). Drivers should always be using popmessage()
instead (has been this way for a while). Augmented popmessage() so
that you can pass NULL to immediately dismiss any messages.
[Aaron Giles, thanks to Oliver Stoneberg's suggestion]
Added ATTR_PRINTF to a number of functions that have printf semantics.
[Oliver Stoneberg]
Rewrote sbrkout driver based on schematics: [Aaron Giles]
* XTAL-based timing
* Correct video timing
* Full memory map
* Correct memory usage ("zero page" RAM is shared with videoram)
* Removed all input hacks
* Fixed interrupt generation
* Connected coin counters
* Added save state support
Fixed several UNICODE=1 issues in the debugger. Changed the Windows
build process to always enable UNICODE=1 for 64-bit builds.
[Oliver Stoneberg, Aaron Giles]
Added save state support to btoads. [Aaron Giles]
Fixed onna34ro mcu simulation properly. [Pierpaolo Prazzoli]
New clones added
Mutant Fighter (World, EM-3) [Stefan Lindberg]
The Simpsons (2 Players Asia) [Arzeno Fabrice]
