Mame 0.121u4
  • 0.121u4
    MAMETesters Bugs Fixed
    namcos22.c_0121u1red [Aaron Giles]
    Source Changes
    Added new option -update_in_pause which enables updating the screen
    bitmap while the game is paused. This is useful for debuggin in
    some scenarios (and gets in the way in others). [Olivier Galibert]
    Added new VIDEO_TYPE_NONE to indicate that there is no screen, and
    fixed internal UI displays to ignore resolution parameters if it is
    specified. [Dirk Best]
    Added missing consts to the files in the emu, lib, and osd
    directories. [Atari Ace]
    Updated drivers to use const structs and arrays where possible.
    [Atari Ace]
    shisen improvements: [Sonikos]
    - added dips location
    - added dips condition
    - remove fake dips coinage
    - fix tow dips in matchit
    Updated inputs in qrouka to support the 3rd and 4th stick. [Sonikos]
    Fixed crash in mngwrite if the game does not have a palette.
    [Nathan Woods]
    SCSP updates: [kingshriek]
    - Added effect-in mixer
    - Added DSP floating-point support
    - Added bounds check to the DECAY1 EG output
    - Fixed the saw PLFO waveform
    - Fixed loop points so loops no longer go out of tune/include
    garbage samples
    Fixed missing profiler call in video.c. [Christophe Jaillet]
    Implemented status flag in Star Wars matrix processor, which affects
    gameplay speed. [Mathis Rosenhauer]
    Changed M37710 CPU to use the CPU clock for its internal timer rather
    than a hard-coded value. Fixes tempo in Namco NA-1 games.
    [Phillip Bennett]
    Fixed accidentally included change that allowed MAME to run in
    windowed mode if switchres was off. [Aaron Giles]
    Midway Zeus improvements: [Aaron Giles]
    * Cleaned up video code, removed unnecessary math
    * Added bilinear filtering
    * Removed perspective correction
    * Added proper video timing configuration
    * Added lightgun support to invasn
    * Increased resolution on fixed point math to prevent overflows
    * Fixed texture addresses to only count even rows
    * Added missing U/V scale factors
    * Added solid polygon rendering support
    * Fixed screen clear trigger
    * Implemented fade out effect
    * Added Z offsets
    * Added support for splitting model commands
    * Hooked up FIFO empty IRQ to make invasn work nicely
    * Correct PIC values for invasn
    * Implemented per-quad texture offsets
    * Hooked up writes to registers during model data processing
    Mortal Kombat 4 [Aaron Giles]
    Shin Nihon Pro Wrestling Toukon Retsuden 3 Arcade Edition
    [R. Belmont, smf, Guru]
    Super World Stadium ´98 [R. Belmont, smf, Guru]
    New clones added
    Trivia Master (set 3) [Eric Marks]
    Kaiun Quiz [R. Belmont, smf, Guru]
    Super World Stadium 2000 [R. Belmont, smf, Guru]
