Code
- 0.120u4
- MAMETesters Bugs Fixed
- gradius4_0120u3yel [Aaron Giles]
- vegas.c0120u3yel [Aaron Giles]
- Source Changes
- Made some minor changes in the inline code. The result of
- atomic_add32 isn´t used a lot of the time, so the final addition was
- brought out to allow it to be optimized away. Removed the unnecessary
- delta argument from atomic_increment32 and atomic_decrement32 in
- eminline.h, and added implementations. Changed the condition for
- using rgbsse.h to include 32-bit platforms with SSE enabled.
- [Vas Crabb]
- Did a major clean-up of the input ports in ssv.c. Brought out the
- common joystick, mahjong and quiz input setups, and then used
- PORT_INCLUDE to pull them in when needed. Also brought out the
- common coinage settings, to avoid needless repetition. [Vas Crabb]
- Analyzed all driver interfaces (DRIVER_INIT, READ8_HANDLER, etc.) to
- determine which ones should be made static and properly tagged them
- all to reduce global namespace pollution. Some cases turned out to be
- dead code, which was also properly tagged. [Atari Ace]
- Updated the Tube Panic driver, fixing the background scroll-in (it´s
- smooth again now). The problem was caused by wrong synchronization
- between main and slave CPUs. Also modified the video driver to be
- scanline accurate and implemented more accurate interrupt handling.
- [Jarek Burczynski]
- Altered TTL low high levels in res_net.c. This will broaden the color
- range a bit. Since the results are normalized, there is only a limited
- effect visible. [couriersud]
- Cleaned up inputs and added dip locations in ms32.c. Also fixed dips
- in "47pie2" and "akiss". [Sonikos]
- Fixed bug that caused incorrect input to be read if multiple inputs
- were mapped to the same mouse input under Windows. [Nathan Woods]
- Fixed a bug in the i8051 core that improperly fired the Timer2
- interrupt when it wasn´t enabled. [Jim Stolis]
- Updates to the peplus driver: [Jim Stolis]
- * Added lightpen support
- * Added PE+ Superboard support
- * Added ABC coin optics support
- * Added full I2C eeprom support
- * Added NVRAM support
- * Corrected door closure issues
- * Removed most memory hacks
- * Consolidated machines and inputs
- * New layout for pepp0158
- Split up the MPU4 driver into a core and driver set up a la NeoGeo.
- Also made some timer fixes, and added some new ROMs added.
- [James Wallace]
- Fixed problems introduced when the junofrst blitter code was
- simplified. [Chris Hardy]
- American Poker II major rewrite: [Roberto Fresca]
- - Properly dervied clocks from crystals
- - Reworked TILE_GET_INFO to handle the proper tiles/color codes.
- - Fixed interrupts (NMI).
- - Corrected AY8910 frequency to 1.5 MHz to match the real thing.
- - Arranged the AY8910 volume in all games avoiding clips.
- - Corrected the screen visible area.
- - Added NVRAM support.
- - Reworked the memory map, mapping all the hardware I/O ports.
- - Reworked the Inputs for all sets.
- - Added implementation of Operator and Supervisor Keys.
- - Fixed some timing troubles.
- - Added partial DIP switch support with diplocations to all sets.
- - Removed the hack in DRIVER_INIT.
- - Hooked write handlers for output ports.
- - Added watchdog routines.
- - Dumped, hooked, wired and decoded the color PROM in all sets.
- - Modified the refresh rate according to hardware measurements.
- - Wired the lamps for all sets. Created their respective layouts.
- - Splitted the driver to driver/video.
- - Other minor fixes.
- SCSP fixes: [kingshriek]
- * Fixed DECAY1 envelope state to not exit immediately
- * Improved support for LPSLNK and SBCTL
- * Fixed panning calculation bug
- * Fixed case where key-rate scaling is off
- Added support for indicating that DIP switches are reversed in the
- DIP locations view. [Vas Crabb]
- Added DIP locations for Midway Tron and the Nintendo Donkey Kong
- series (dkong.c). [Vas Crabb]
- Added an Altivec/VMX implementation of the RGB utilities for our
- friends with G4, G5 and POWER5 CPUs (rgbvmx.h) and added
- rgbint_bilinear_filter and rgbaint_bilinear_filter to rgbsse.h (based
- on rgb_bilinear_filter/rgba_bilinear_filter) for completeness, as
- these functions exist in rgbgen.h. [Vas Crabb]
- Updated model2.c, taitojc.c, and gticlub.c to use the new polygon
- routines. Deprecated the old poly.c and renamed polynew.* to poly.*.
- [Aaron Giles]
- Unified poly.c callbacks so that tri and quad callbacks work the
- same way. [Aaron Giles]
- Fixed display of floating point TMS32031 registers in the debugger.
- [Aaron Giles]
- Fixed TMS32031 ABSF opcode to work as documented and not produce a
- proper negative. [Aaron Giles]
- New games added or promoted from NOT_WORKING status
- Player´s Edge Plus (PP0516) Double Bonus Poker [Jim Stolis]
- Player´s Edge Plus (PP0158) 4 of a Kind Bonus Poker [Jim Stolis]
- Player´s Edge Plus (PP0188) Standard Draw Poker [Jim Stolis]
- Player´s Edge Plus (Set038) Set Chip [Jim Stolis]
- Player´s Edge Plus (BE0014) Blackjack [Jim Stolis]
- Player´s Edge Plus (KE1012) Keno [Jim Stolis]
- Player´s Edge Plus (PS0615) Video Slots [Jim Stolis]
- Player´s Edge Plus (PS0716) Video Slots [Jim Stolis]
- Player´s Edge Plus (XP000019) Deuces Wild Poker [Jim Stolis]
- Player´s Edge Plus (XS000006) Triple Triple Diamond Slots [Jim Stolis]
- MPU4 Unit Test [James Wallace]
- Sigma Poker [Roberto Fresca]
- New clones added
- Slipstream (950515 HISPANIC) [Guru]
- Kick and Run (US) [Brian Troha]
- American Poker 95 [Roberto Fresca]
- Poker De Win [Roberto Fresca]
- New games marked as GAME_NOT_WORKING
- Vegas Poker (Prototype) [James Wallace]
- Sigma Poker 2000 [Roberto Fresca]
