0.116u2
MAMETesters Bugs Fixed
adk0116yel [Zsolt Vasvari]
neodrvr0116u1red [Zsolt Vasvari]
strhoop0116u1red [Zsolt Vasvari]
wb3_0116u1gre [Aaron Giles]
Source Changes
Fixed regressions in Gridlee and Gomoku. [Zsolt Vasvari]
Fixed some unicode build issues in the Windows code.
[Oliver Stoneberg]
Updated a number of games to correctly use the SN76489 instead of the
SN76496, which was a later design. [Justin Kerk, Lord Nightmare]
Cleaned up the exports from a number of drivers, adding static
qualifiers to functions and variables t hat don't need to be exported
and have generic sounding names. [Atari Ace]
Updated numerous drivers to remove the use of global Machine wherever
possible. Also reviewed the clipping regions and made changes to
ensure the passed-in cliprect was honored. [Zsolt Vasvari]
Cleaned up the Dooyong driver: [Vas Crabb]
* Consolidated and streamlined tilemap callbacks
* Took better advantage of MAME's tilemap caching by building
larger tilemaps so they don't need to be invalidated as often
* Interpreted sprite Y position as signed 9-bit value in
rshark/superx (fixes some glitches)
* Added more explanatory comments to help others reading the code
Changed a number of mame timer objects from void * to mame_timer *.
[Atari Ace]
Fixed a couple more Irem CPU opcodes to improve Match It 2.
[Robiza]
Fixed collision detection bug in thunderX. [Shimapong]
Initial cut at working CPS3 driver. Basically works but has a lot
more work to be done to finish it up.
[David Haywood, Andreas Naive, Tomasz Slanina, ElSemi, Philip Bennett]
Fixed minor cycle timing issue in 6809 CPU core. [Ernesto Corvi]
Neo-Geo updates: [Zsolt Vasvari]
* Fixed several regressions from previous update
* Added LED outputs
* Improved smaller visible area configuration
Fixed some incorrect information in the Neo Geo ROMsets. [JohnBoy]
Integrated platform-specific changes into the core makefile, mostly
taken from the SDLMAME makefile. Changed the MAMEOS configuration
variable to OSD, indicating which OSD layer is being compiled. Added
a new configuration variable TARGETOS which specifies the target OS
platform. [Aaron Giles]
New clones added
Punch-Out!! (Italian bootleg) [David Haywood]
Mini Boy 7 [Roberto Fresca]
