Mame 0.116
  • 0.116
    MAMETesters Bugs Fixed
    oscar0111u3yel [ShimaPong]
    toypop0115u4red [Aaron Giles]
    profpac0115u4gre [Aaron Giles]
    seawolf2_0115u2gra [Aaron Giles]
    konek0115u4yel [Aaron Giles]
    9ballsht0115u3gre [Aaron Giles]
    csuperas0104u7gre [ShimaPong]
    exerion0112u4yel [ShimaPong]
    Source Changes
    Major Donkey Kong driver update: [couriersud]
    - Implemented discrete sound from schematics: dkong, radarscp
    - Implemented discrete background from schematics for radarscp and
    various effects:
    - blue to black to blue background
    - exact priorities
    - Grid will flip open and close, vertical flipping on hit.
    - Changed inputs for radarscp
    - Color generation from schematics (resistor mixer) for
    radarscp, dkong, dkongjr and dkong3
    Added new components to the discrete sound system: [couriersud]
    - Added a "inverter oscillator" component. This can also be used as
    a raw sine generator - needed by radarscp.
    - Added a "integration circuit" based on transistor and RC
    - Added a "modulated RC discharge" component.
    Removed unused return value from VIDEO_START callbacks.
    [Zsolt Vasvari]
    Improved independence of CPU and sound core variants in order to make
    them more properly separated by the existing compile-time flags.
    [Atari Ace]
    More TIA updates from MESS: [Wilbert Pol]
    - Rewrote drawing of playing graphics
    - Improved handling of player graphics reset signals
    - Improved handling of HMOVE signals
    Updates to Change Lanes: [Adam Bousley]
    - fixed the broken graphics
    - fixed the dipswitches
    - hooked up the steering wheel controls
    - made some changes to the sprite and text layers based on schematics
    Fixed up a number of places where malloc results weren't being checked
    correctly. [Atari Ace]
    Renamed palette_set_color() to palette_set_color_rgb().
    palette_set_color() now matches palette_get_color() and deals in
    rgb_t data only. Also changed palette_set_colors() to deal with rgb_t
    data instead of R,G,B triples. [Aaron Giles]
    Flattened colormap and palette in the 1942 driver. [Aaron Giles]
    Removed usage of unsigned char/short/int from the drivers code in
    favor of UINT8/UINT16/UINT32.
    Mahjong G-Taste [David Haywood]
    New clones added
    Buzzard [Zsolt Vasvari]
