0.115u3
MAMETesters Bugs Fixed
connect4_0115u1ora [Luigi30]
Source Changes
Fixed PIA numbers in revamped Spiders driver. [Zsolt Vasvari]
Updated TIA graphics code is the code from the MESS repository. Also
updated tourtabl driver to accommodate the changes. [Wilbert Pol]
Fixed Space Firebird so that the sprites are opaque with respect to
each other and bullets, but transparent with respect to the star
field. [Zsolt Vasvari]
Fixed subtle behavior in handling of PIA port A. This allows for the
removal of hacks in the Qix driver and the Williams driver.
[Zsolt Vasvari]
Cleaned up the tilemap get_info callbacks: [Atari Ace]
* regularized and clean up the existing callbacks
* changed some callbacks to use int tile_index as the parameter
so that all callbacks use consistent naming
* folded some direct uses of tile_info.flags into calls to
SET_TILE_INFO()
* changed the Konami drivers to manipulate the tile_info global only
within the tile_get_info callbacks
* replaced all the callback declarations with TILE_GET_INFO()
wrappers
* changed the interface to pass tile_info as a parameter and made
tile_info a static variable only accessible inside tilemap.c.
Significant changes to the berzerk driver: [Zsolt Vasvari]
- Video timings, memory map and interrupt system implemented from
schematics
- Hooked up colors according to the schematics as well. The colors
changed significantly. For example the yellow robots are now
more like a mustard color.
More ARM wrestling: [R. Belmont]
- Fixed error in carry propagation on ALU opcodes of the form
ALU r1, r2, r3 SHIFTEROP #imm
- Fixed Thumb ADD instructions where the PC is involved
- Fixed LDMIA to mask off bits 0 and 1 of the destination address
- MSR instruction now properly respects processor mode and field
code flags
Modernized the Beam Invaders, Clay Shoot, and Embargo drivers.
[Zsolt Vasvari]
Changed the sound balance in Thunder Dragon 2 to match the original
PCB. Also verified the 68000 clock. [Corrado Tomaselli]
Fixed several more opcodes in the encrypted Irem CPU. [Robiza]
Fixed disassembly of brset and brclr opcodes in the 68HC11 core.
[Phil Skuse]
Fixed tilemap colors in the Konami ZR107 driver. [Ville Linde]
Fixed bug in INR/DCR opcodes in 8085 CPU core. [allentown_john]
Updated PIA interfaces to support masks for port A/B inputs. This
allows proper behavior of unconnected pins, according to the specs.
Updated a number of games to use the new interfaces. [Zsolt Vasvari]
Fixed bug that failed to initialize all IRQ states in the 6809 core
on a reset. Also fixed cycle timing and removed obsolete code from
the core. [Ernesto Corvi, Zsolt Vasvari]
Cleaned up vec_mult implementation. [Nathan Woods]
Improved toratora driver: [Zsolt Vasvari]
- added SN76477 from the schematics, but it sounds terrible; no doubt
the schematics are incorrect in many places
- updated to the recent PIA changes
Fixed input.c to use osd_ticks() instead of clock(). [Nathan Woods]
Fixed bit calculation in 6526cia.c which broke joysticks in the C64
driver in MESS. [Pete Rittwage]
Improvements to the rd2tank driver: [Zsolt Vasvari]
- fixed colors, based on the Red Tank flyer
- added AY8910's, sounds fine, but how exactly they are hooked up
to the PIA is not fully understood.
- hooked up CRTC properly
Wild Arrow [Zsolt Vasvari]
G-Stream G2020 [David Haywood]
New clones added
Multi Game (set 2) [Roberto Fresca]
19XX: The War Against Destiny (Brazil 951218) [Nicola Salmoria]
Thunder Dragon 2 (9th Nov. 1993) [Corrado Tomaselli]
Flicky (128k Version, System 2, not encrypted) [Corrado Tomaselli]
Flicky (64k Version, System 1, 315-5051, set 2) [Corrado Tomaselli]
