0.115u1
MAMETesters Bugs Fixed
asserts0115ora [Aaron Giles]
scregg0115red [Zsolt Vasvari]
mysticri36rc2gre [Pierpaolo Prazzoli]
m92c053gre2 [Pierpaolo Prazzoli]
aerofgt.c0115ora [Roberto Fresca]
midyunit0115red [couriersud]
nekkyoku0115red [couriersud]
exerion0112u4yel [Pierpaolo Prazzoli]
dragngun067yel [R. Belmont, Ryan Holtz -- please verify]
cidelsa0114u4gre [Aaron Giles]
missile0115yel [Aaron Giles]
Source Changes
Added support for playback of "extended" INP files that are commonly
found on compete sites. [David Haywood]
Added lswx and stswx opcodes to the PowerPC core. [Ville Linde]
Changed DRIVER_INIT macro to prepend driver_init_* instead of simply
init_* to be consistent with the other initialization functions.
[Atari Ace]
Corrected the pulse shape of the timer output in the MPU4 driver,
and also correctly identified the AY sound chip as an AY8913.
[James Wallace]
Merged leprechn driver into the gameplan driver and added correct
video timings. [Zsolt Vasvari]
Cleaned up the dorachan driver. Replaced fake color map with actual
color PROM decoding. [Zsolt Vasvari]
Cleaned up the supertnk driver. [Zsolt Vasvari]
Move Atari vector PROMs into separate regions. [Mathis Rosenhauer]
Added DIP switches for Excite League. [Barry Harris, Yasuhiro Ogawa]
Improved m92 sprite drawing. [Pierpaolo Prazzoli]
Rewrote the magicfly driver: [Roberto Fresca]
- Figured out how the protection works.
- Removed the hacks/patchs that formerly allow boot the games.
- Figured out how the buffered inputs works.
- Demuxed all inputs for both games.
- Unified the memory maps from both games.
- Added NVRAM support to both games.
- Mapped DIP switches.
- Managed the planes to get the 3bpp GFX colors accurate.
- Renamed the ROMs acording to pcb pictures and ROM contents.
- Cleaned up and optimized the driver.
Fixed throttle range in gforce2. [David Haywood]
Moved Win32 UTF-8 wrappers into a new module (winutf8.c), and added
some new wrappers that Oliver Stoeneberg created for MAME32.
[Nathan Woods]
Aleck64/N64 update: [Ryan Holtz]
- RSP: some opcodes bugfixed plus should work on big-endian targets
- Real PIF ROM dump now used and required
- Various other fixes
Fixed eeprom handling in surfplnt. [couriersud]
Fixed carry flag calculation for SUB/SBC/CMP family instructions in
the ARM core. [R. Belmont, Ryan Holtz]
Improvements to the ARM7 core: [R. Belmont, Ryan Holtz]
- fixed 32-bit unaligned reads to "scramble" properly
- fixed carry flag calc for SUB/SBC/CMP family instructions
- fixed multiply-and-accumulate instructions
- added more instructions to the disassembler
- fixed logical and arithmetic shifts
- added more Thumb instructions
- fixed relative loads and stores
- fixed LSL/LSR with zero shift values
- fixed the disassembly of CMN
- verified behavior when ADD destination is the PC on real h/w
Rewrote the Space Firebird driver: [Zsolt Vasvari]
- Added star field, matches with the screen shot perfectly
- Video timings/memory map/interrupts from schematics
- Added support for the color fade effect
Identified a couple of new opcodes in the Irem V30 CPU which improves
matchit2. [Pierpaolo Prazzoli]
Significantly cleaned up the Spiders driver. [Zsolt Vasvari]
Changed memory system behavior so that masks can be specified
independently of mirrors. By default if the mask is 0 and a mirror
is present, the mask is implicitly ~mirror, just as before. But if a
mask is specified, it is not limited to the non-mirrored bits. This
allows you to independently control the mapping versus what is
returned to the read/write handler. [Aaron Giles]
Rewrote Astrocade driver: [Aaron Giles]
- fully implemented all function generator modes
- implemented pattern board according to schematics, including timing
- fixed interrupt handling
- added crosshairs to SeaWolf II
- added stereo sound and panning to SeaWolf II samples
- rewrote Astrocade sound emulation according to patent
- sound generation now uses proper LFSR for noise effects
- added partial support for Ten Pin Deluxe, including sound board
emulation and internal layout
Fixed sound in Inferno after all these years. Sadly, it required a
hack. [Aaron Giles]
Added correct video timings for the Williams games. [Aaron Giles]
Added support for misaligned PIXBLT operations in the TMS34010 core.
The code still needs cleanup but improves the new JPM driver.
[Aaron Giles]
Magic Fly [Roberto Fresca]
7 e Mezzo [Roberto Fresca]
New clones added
Captain Silver (World) [David Haywood]
Ten Pin Deluxe [Aaron Giles]
