MAME 0.112u4
  • 0.112u4
    MAMETesters Bugs Fixed
    speakres0112yel [Zsolt Vasvari]
    minigolf0112u2gra [Derrick Renaud]
    empcity36finalyel [Aaron Giles]
    rdtsc0101u5yel [Aaron Giles]
    Source Changes
    Discrete sound for Checkmate: [Derrick Renaud]
    * new DISCRETE_ADJUSTMENT_TAG module that uses tags instead of port
    numbers. Updated all games to use it, because it is now the
    preferred method.
    * added PORT_CROSSHAIRs to triplhnt.
    Minor Konami 573 system update: [smf]
    * marks two games as working which were incorrectly tagged
    * adds the correct hashes for 845jab02
    * added NO_DUMP's for all the flash roms
    Fixed a number of issues related to the new streaming engine and
    sound code: [Aaron Giles]
    * fixed crash when restoring from a save state
    * fixed crash when running with -nosound
    * fixed loud looping when halted in the debugger
    * fixed crash when changing sample rates (YM2203 mainly)
    * fixed crash in k054539 sound core
    Added SN76477 noise RNG polynomial. [Zsolt Vasvari, Derrick Renaud,
    Jarek Burczynski]
    Midway 8080 driver updates: [Zsolt Vasvari]
    * fixed bug where mw8080bw games would freeze after state load.
    * corrected DIP SW order in M-4
    * converted Dog Patch to PORT_POSITIONAL
    RF5C400 sound core improvements: [hoot development team]
    * implemented volume envelopes
    * ccorrected the channel volume calculation
    * documented registers for reverb, chorus, and per-channel digital
    filter (actual effects are not implemented yet)
    Fixeed most Dip Switches and Inputs in the galspnbl driver.
    [stephh, Justin Szczap]
    Updated a number of drivers to use the new PORT_DIPUNUSED macros.
    [stephh]
    Improvements to the memory pool routines: [Nathan Woods]
    - added a pool_clear() call, to clear out a memory pool without
    freeing the pool itself
    - added support for pool_realloc() with a size of zero, which
    effectively frees a pointer within a pool
    - added testing code to validate pool behavior
    Added support for more flexible word wrapping with CJK characters.
    Also added wrapping on hyphens. [MAME Plus! team, Aaron Giles]
    Added T5182 support, which gives sound to darkmist, mustache and
    panicr. Also changed the YM2151 to prevent timer problems, and added
    the missing flip X in Mustache Boy. [Nicola Salmora, Lord Nightmare,
    Ernesto Corvi]
    More input fixes and improvements: [Derrick Renaud]
    * fixed some obscure masking, shifting, overflow, and signed
    problems in the input system. Most noticeably this fixes the
    analog controls in sfootbal and stops the pedal in redlin2p from
    rotating through gas/no gas as the pedal is pressed.
    * analog ports no longer save and load their default value from the
    config file. It should only ever use the value specified in the
    driver, and storing it can cause problems the more the game is
    restarted and the value starts to change.
    * added a bunch of validity tests to the analog ports. Some are
    commented out until the problems they uncovered are fixed.
    * analog ports now defalt to a PORT_MINMAX of (0,mask). This means
    you no longer have to specify PORT_MINMAX if you are not using
    any limits. Removed a bunch of no longer needed PORT_MINMAX
    entries.
    Bitmaps are now cleared to 0 by default. This fixes a number of random
    crashes in games. [Aaron Giles]
    Modified the raster position calculations to round to the nearest
    pixel which produces more consistent results. [Aaron Giles]
    Changed most sound cores to generate audio at their internal clock
    rates (or some multiple/divisor of them) rather than at the user
    specified output rate. This completes the second step of decoupling
    audio emulation from the user's sample rate choice. [Aaron Giles]
    Removed a big pile of goofiness from the DMA-driven DAC driver now
    that it is no longer necessary. [Aaron Giles]
    Removed custom sound code from cchasm and replaced it with a simple
    DAC implementation. [Aaron Giles]
    Cleaned up attckufo driver, making it perform like a 1MHz 6502 game
    once again. [Aaron Giles]
    Tokimeki Memorial Oshiete Your Heart [R. Belmont]
    Tokimeki Memorial Oshiete Your Heart Seal version PLUS [R. Belmont]
