0.112u1
IMPORTANT: This release brings with it a major source code
reorganization. Because of this, there is no diff update, since the
diff would be enormous.
The new layout at a high level looks like this:
makefile
docs/
src/
emu/ (generic emulation files from the old src/ directory)
cpu/ (CPU cores from src/cpu)
sound/ (sound cores from src/sound)
debug/ (debugger code from src/debug)
audio/ (generic audio files from src/sndhrdw)
layout/ (generic layout files from src/layout)
machine/ (generic machine files from src/machine)
video/ (generic video files from src/vidhrdw)
mame/ (MAME-specific drivers)
drivers/ (drivers from src/drivers)
includes/ (includes from src/includes)
layout/ (majority of files from src/layout)
machine/ (majority of files from src/machine)
audio/ (majority of files from src/sndhrdw)
video/ (majority of files from src/vidhrdw)
etc/ (misc files from src/etc)
lib/ (libraries)
util/ (various files with light dependencies from src)
zlib/ (zlib library)
expat/ (expat library)
osd/ (OS-dependent code)
osdmini/ (mini OS-dependent code)
windows/ (Windows OS-dependent code)
tools/ (misc tools)
Along with these changes come a number of makefile alterations to
better distribute the build knowledge within each major subdirectory.
There may be some build issues or other interesting side effects to
this change. Report them on MAMETesters and future updates will
include fixes.
MAMETesters Bugs Fixed
m4_0111u4gra [Mike Ellery]
mouser0112yel [Mamesick]
bnj0111u5ora [Canim]
Source Changes
Improvements to the Cidelsa driver: [Curt Coder]
- Fixed the disassembly of cdp1802 opcode LSKP
- Changed the cdp1802 opcode OUT to increment R(X) after calling the
write handler
- Set cdp1869 display size and visible area according to data sheet
- Added cdp1869 CFC emulation (probably never used by anything but
just for completeness' sake)
- Cleaned up driver
Improvements to the M2 driver: [Ville Linde]
- Added preliminary CD controller emulation
- Hooked up some more multi-processor functionality and interrupts
Improvements to C352 sound emulator: [cync, hoot development team]
- Rewrote loop and flag handling, added support for global key-on
register
- Fixed state saving
Worked around compilation error on MSVC that caused "Calendar error"
in the Neo Geo games. [Atari Ace]
Rewrote much of the RF5C400 sound emulator to support looping, stereo
panning, and 8-bit sample support.
[hoot development team, Ville Linde]
Removed patch from mjleague now that it is not needed.
[Arenzo Fabrice]
Fixed bubbletr crosshairs. [Canim]
Cleaned up information in mamedriv.c. [Brian Troha]
Added save state support for all games in gng.c, gunsmoke.c, lasso.c,
solomon.c and terracre.c. [Vas Crabb]
Replaced implementation of Namco 54xx sound chip with new MB8844 CPU
core running the original embedded ROM code. Removed old sound core.
Pole Position and Bosconian no longer require samples as a result.
[Nicola Salmora, Ernesto Corvi, Guru]
Added new function driver_get_count() to return the number of drivers.
[Nathan Woods]
Added a bunch of new protection routines for SD Gundam & Heated
Barrel. [Angelo Salese]
Input system changes: [Derrick Renaud]
- Added new IPT_POSITIONAL control type. This is for Ikari type
rotary controls and gray-code devices like Seawolf. This makes
rotary and gray-code controls easy to enter without custom
handlers.
- Fixed some rounding and min/max errors in the core input code.
- Modified crosshair code to be based on real scaling, see Seawolf
for an example. It can now also have multiple crosshairs on one
input port if needed.
- Added back in the namcos2 crosshairs. Turns out they are needed
for calibration.
- Removed the gwar control hack from the Ikari games that did not
need it. Modified the gwar control hack so it is only used for 1
frame, making it unnoticeable.
- Updated boothill, gunfight, seawolf, spcenctr to use the new
PORT_REMAP_TABLE.
Fixed the exidy/stern-sb1000 6840-based sound hardware to use what
is believed (based on the schematic) to be the proper LFSR/PRNG
waveform for its secondary clock source. [Lord Nightmare]
Updated Dragon Bowl to use HOLD_LINE for sound IRQs. Also did the same
for the following drivers: afega, ettrivia, funybubl, jack, mustache,
seta, trvmadns, wink. [Pierpaolo Prazzoli]
Changed 6809/6309 CPU cores to call the MAME debugger when CWAI/SYNC
is used. [Nathan Woods]
Fixed uninitialized use of video_dma_address to address the rfjet
crash in 64-bit builds. [Ville Linde]
Added support for the Motorola MPC8240 to the PowerPC core.
[Ville Linde]
Improved ZIP file searching to look first for name + CRC match, second
for CRC-only match, and lastly for name-only match. [Ben Rudiak-Gould]
Verified and improved stepper behavior based on comparison with a
real machine. [James Wallace]
Changed file2str to work for any binary file and output the data as
an array of bytes rather than a string. [Aaron Giles]
Made UI font size computations more flexible. This ensures that fonts
are scaled vertically by an integral factor and should produce nice
proportions for most fonts now. [Aaron Giles]
Added new function sound_find_sndnum_by_tag() to look up a sound
index by its tag. [Aaron Giles]
Made osd_uchar_from_osdchar a member of the osdcore file library.
[Aaron Giles]
Created new generic bitmap management code with fewer dependencies on
the rest of MAME so that it can be used by utility code. Changed
bitmap_alloc to always take a format parameter. Deprecated
bitmap_alloc_format. Updated all drivers to pass an explicit format
when allocating a bitmap. Changed auto_bitmap_alloc in the same
fashion. [Aaron Giles]
Split some functionality from fileio.c into new module corefile.c,
which can be used by utilities to get unicode support and fopen-style
file I/O built on top of the OSD routines. Rebuilt fileio.c on top of
the core file code. Added mame_core_file() to get the underlying
core_file object from a mame_file so it can be used with png and
xmlfile code. [Aaron Giles]
Changed the way the tiny build works. There is now the concept of a
SUBTARGET. By default SUBTARGET is set equal to TARGET (which is mame)
and everything builds as normal. The makefile that is included is now
src/$(TARGET)/$(SUBTARGET).mak. Thus, to do a tiny build, you now
have to specify "make SUBTARGET=tiny". This will produce an output
executable with a name $(TARGET)$(SUBTARGET) (mametiny in this case).
[Aaron Giles]
Turned ENABLE_BORDER_PIX back on, since so many people seem to be
having trouble without it. [Aaron Giles]
Cash Quiz [Pierpaolo Prazzoli]
Sidewinder [smf]
New clones added
Power Spikes (China) [Pierpaolo Prazzoli]
Rastan Saga (Japan Rev 1) [Gerald Coy]
Eco Fighters (USA 931203) [Nicola Salmoria]
Ultimate Ecology (Japan 931203) [Nicola Salmoria]
Eco Fighters (Asia 931203) [Nicola Salmoria]
Night Warriors: Darkstalkers' Revenge (Hispanic 950403) [Nicola]
Night Warriors: Darkstalkers' Revenge (Brazil 950403) [Nicola]
