0.111u5
MAMETesters Bugs Fixed
bitmapalloccore0111u4red [Aaron Giles]
8080bw0111u4red [Zsolt Vasvari]
sidvoice0111u4ora [Nathan Woods]
pyramid0111u4red [James Wallace]
dragngun0111u3gra [Canim]
mitchelc0111u3gra [Luigi30]
lockload0111u3gra [Canim]
cobracom0111u3ora [Canim]
Source Changes
Fixed a 6502 register naming bug, and fixed a size bug in the
SC61860 disassembler. [Nathan Woods]
Added built-in overlay layout for Crash. [Mr. Do]
Added save state support to Gyruss. [Buddabing]
Fixed missing sound interfaces from the MESS sound core merge.
[Nathan Woods]
Fixed several duplicated global variable names, removed unreferenced
items from header files, and added header files for several drivers.
[Atari Ace]
Changed debug console code to use auto_malloc and to detect attempts
at registering callbacks after initialization time. [Nathan Woods]
Fixed kof2003 bootleg code to work on big-endian systems. [R. Belmont]
Centralized some common Windows utility routines in new module
winutil.c. [Nathan Woods]
Cleaned up a few drivers to use input_port_dword_*_r. [smf]
Cleaned up memory maps in the MPU4 and BFM drivers. Redesigned the
MPU4 code so that the DRIVER_INIT only needs to take an address in
the ROM for the lookup table for CHR generation to be done.
[James Wallace]
Updated built-in expat code to version 2.0. [Atari Ace]
Fixed sound samples in Indian Battle. [Zsolt Vasvari]
Added state saving to mhavoc. Also fixed sparkling vectors so
slowdowns and vector list overflows can be expected. It looks much
nicer, though. [Mathis Rosenhauer]
Removed XORs from almost all CPS2 games in place of proper emulation
of the encryption. [Nicola Salmoria]
Added an assertion to prevent usage of pia_set_input_[a|b]() when
input reading callbacks are specified. [Nathan Woods]
Fixed flip screen switch and changed COIN3 to SERVICE1 in the contra.c
driver. [Canim]
Cleand up and fixed DIP switches and inputs for the nmg5 driver.
[stephh]
Rewrote Z80 interrupt handling to avoid a bad bug in the post-EI
interrupt signalling. [Aaron Giles]
Added documentation to the esd16, afega, cave, unico, vamphalf, and
yunsun16 drivers. [Brian Troha]
Changed behavior in chdman so that a 0 sector size means the default.
[Aaron Giles]
Updated several video drivers (amiga, n64, ppu2c0x, psx, stvvdp2,
tia, v9938) to use the new BITMAP_ADDR* macros instead of using the
line[] array. [Nathan Woods]
Some additional Midway 8080 B&W driver fixes: [Zsolt Vasvari]
- added PORT_CONDITION where needed
- added PORT_CONFNAME entries to the 3 baseball games and Space
Invaders
- save state support for all games
- fixed typo and a bug with the Sea Wolf lamps
Fixed a minor problem with sound clipping in the s14001a.
[Lord Nightmare]
Fixed PRNG noise in the TMS5110/5220 code and added signal wrapping
to match the patent. [Lord Nightmare]
Cleaned up usage of auto_bitmap_alloc() now that it is guaranteed not
to fail. [Aaron Giles, Atari Ace]
Added sound effects emulation to the Berzerk driver. [Aaron Giles]
Fixed font aspect ratio on non-1:1 resolutions. [Aaron Giles]
Added mechanism to cache a binary format of BDF fonts for improved
loading speed. Also added a bit of progress when loading huge BDF
fonts so that you know what's happening. [Aaron Giles]
Removed gross TMS9928a configuration in place of more standard
techniques. Updates the Cliffhanger and sg1000a drivers accordingly.
[Aaron Giles]
Added support for the custom Badlands commands to the LD-V1000
emulation. [Aaron Giles]
Dream World [David Haywood, Guru]
New clones added
Multi 5 / New Multi Game 5 (Earlier) [Brian Troha]
Bubble Bobble (bootleg with 68705) [David Haywood]
Super Street Fighter II (World 930911) [Nicola Salmoria]
Super Street Fighter II (Japan 930911) [Nicola Salmoria]
Dungeons & Dragons: Tower of Doom (Euro 940113) [Nicola Salmoria]
Super Street Fighter II Turbo (USA 940323) [Nicola Salmoria]
Armored Warriors (Euro 941024) [Nicola Salmoria]
Alien vs. Predator (Hispanic 940520) [Nicola Salmoria]
Cyberbots: Fullmetal Madness (Euro 950424) [Nicola Salmoria]
Marvel Super Heroes (Euro 951024) [Nicola Salmoria]
Marvel Super Heroes (Japan 951117) [Nicola Salmoria]
Marvel Super Heroes (Brazil 951117) [Nicola Salmoria]
Vampire Hunter: Darkstalkers' Revenge (Japan 950307) [Nicola Salmoria]
Street Fighter Alpha: Warriors' Dreams (Euro 950627) [Nicola Salmoria]
19XX: The War Against Destiny (Japan 951225) [Nicola Salmoria]
Dungeons & Dragons:Shadow over Mystara (Euro 960223) [Nicola Salmoria]
Dungeons & Dragons:Shadow over Mystara (Euro 960208) [Nicola Salmoria]
X-Men Vs. Street Fighter (Euro 961004) [Nicola Salmoria]
Capcom Sports Club (Hispanic 970722) [Nicola Salmoria]
Marvel Super Heroes Vs. SF (Euro 970625) [Nicola Salmoria]
Marvel Super Heroes Vs. SF (Japan 970625) [Nicola Salmoria]
Marvel Super Heroes Vs. SF (Hispanic 970625) [Nicola Salmoria]
Marvel Super Heroes Vs. SF (Brazil 970827) [Nicola Salmoria]
Marvel Super Heroes Vs. SF (Brazil 970625) [Nicola Salmoria]
Vampire Hunter 2 (Japan 970929) [Nicola Salmoria]
Vampire Savior (Hispanic 970519) [Nicola Salmoria]
Marvel Vs. Capcom (Euro 980112) [Nicola Salmoria]
Marvel Vs. Capcom (Asia 980123) [Nicola Salmoria]
Marvel Vs. Capcom (Hispanic 980123) [Nicola Salmoria]
Marvel Vs. Capcom (Brazil 980123) [Nicola Salmoria]
Street Fighter Alpha 3 (Brazil 980629) [Nicola Salmoria]
Street Fighter Zero 3 (Asia 980904) [Nicola Salmoria]
Vs. Super Mario Bros. (alt) [Lord Nightmare]
Two Minute Drill [David Haywood]
Super Don Quix-ote [Ernesto Corvi]
