Hi there.
I have just installed MaLa and then browsed to locate the mame0110b.exe file (windows command line version). It starts 'extracting' but at the end MaLa brings up an error message saying: Unexpected error. and in the Mala.exe.txt file is the following information:
2006/12/10 19:35:25.00 Error: Object Class: TTabSheet, Object Function: AppDeactivate, Exception Class: EStringListError, Exception Message: Der Index der Liste überschreitet das Maximum (0)
2006/12/10 19:46:28.85 Error: Object Class: TTabSheet, Object Function: GpKeyboardHook1KeyAction, Exception Class: EStringListError, Exception Message: Der Index der Liste überschreitet das Maximum (0)
2006/12/10 19:46:53.59 Error: Object Class: TTabSheet, Object Function: AppDeactivate, Exception Class: EStringListError, Exception Message: Der Index der Liste überschreitet das Maximum (0)
As you can see I have tried this several times but with no luck.
Any ideas? Thanks
