MAME 0.110u2
  • 0.110u2
    MAMETesters Bugs Fixed
    vulcan137b1gre [robiza, Mamesick]
    mario0110u1gre [Derrick Renaud]
    Source Changes
    Fixed flags access in the i286 core. [Barry Rodewald]
    Updated MC146818 module to use new core date/time routines.
    [Nathan Woods]
    Cleaned up disassemblers to remove stubs and ensure the disassemblers
    are not referenced except in debug builds. [Nathan Woods]
    Added support for using CHDs to decrypt CPS2 games. This code is
    disabled for the moment, but will be enabled in the future. Only a
    handful of games have complete tables so far. These tables are huge
    (~4GB) and uncompressable until the encryption algorithm is
    understood. [David Haywood]
    Fixed bug in the debugger that caused watchpoints to not be active
    until the next context switch. [smf]
    Cleaned up the input definitions for n-way joysticks so they are
    more explicit. Added concept of a "16-way" joystick, which is a
    joystick that doesn't prevent simultaneous opposing directions from
    bring reported. [smf]
    Major System 573 update: [smf]
    * fixed PSX SIO control register behavior
    * implemented several SCSI CD commands: START/STOP UNIT, PAUSE/
    RESUME, READ SUB-CHANNEL, READ TOC
    * added uPD4701 emulation
    * fixed ATAPI reset, PIO, and command IDENTIFY PACKET DEVICE
    * hooked up controls for fishing, DRR, and Guitar Freaks games
    * hooked up CDDA audio
    * removed some unused bytes from the Konami 80's security chips
    Fixed upside down service mode in the commando.c driver. [Canim]
    Added support for the Triple Hunt 8-track audio. [Derrick Renaud]
    Galaxian/Scramble driver reorganization: [Atari Ace]
    * machine/scramble.c is broken up into two files,
    machine/galaxian.c and machine/scramble.c
    * drivers/amidar.c, drivers/frogger.c, drivers/scobra.c get copies
    of some of the data structures they shared from other drivers
    * galaxian_base is made static and uses outside of the main driver
    were rewritten
    * cclimber_decode code from drivers/cclimber.c was separated into
    its own machine/cclimber.c file to allow mshuttle to share it
    without taking on other dependencies
    Added missing x-flipping support in Major Havoc. [Mathis Rosenhauer]
    Made some improvements to trivia madness driver. There still is
    something wrong in the question roms banking. [Pierpaolo Prazzoli]
    More updates to the ST-V driver: [Mariusz Wojcieszek]
    * vdp1: added shading for sprites (used by znpwfv, cotton, others)
    * vdp1: fixed sprite clipping (fixes incorrect sprites in znpwfv)
    * vdp1: fixed transparency on colour lookup table sprites (fixes bad
    sprites in znpwfv)
    * vdp2: fixed caching of RGB layer (fixes bad backgrounds on bosses
    in rsgun)
    * vdp2: added additive blending for tilemaps and sprites (rsgun)
    * vdp2: added vertical line scroll and linezoom (fixes diehard logo)
    * stv: improved speedups for diehard
    * stv: fixed speedups for znpwfv
    * stv: added preliminary save state support
    Significant cleanup of chd.c: [Aaron Giles]
    * got rid of the horrible last_error concept; now all routines
    return an error directly
    * fixed several issues in managing metadata
    * changed compression and verification routines to be client-driven
    rather than monolithic
    * changed internal codec usage to be more flexible
    * altered chdman and MAME to use the new interfaces
    * added new -createraw command for creating raw data CHDs
    Fixed crash bug in romcmp when comparing ZIP files. [Aaron Giles]
    Fisherman's Bait * A Bass Challenge / Bass Angler [smf]
    Fisherman's Bait 2 * A Bass Challenge [smf]
    Fisherman's Bait * Marlin Challenge [smf]
    Dancing Stage / Dance Dance Revolution [smf]
    Guitar Freaks [smf]
    Dance Dance Revolution 2nd Mix [smf]
    Dance Dance Revolution 2nd Mix Link [smf]
    New clones added
    Hellfire (2P Ver., first edition) [Tirino73]
    Konami 80's AC Special (3 versions) [smf]
    Stratovox (bootleg) [Brian Troha]
