Mame 0.109u1
  • 0.109u1
    IMPORTANT NOTE TO OSD DEVELOPERS: The file I/O interface has changed
    significantly. It is now much simpler. Please read osdepend.h for
    full details on how the new OSD-defined functions work. In addition,
    you must now use the options.c to specify your search paths. If you
    are parsing standard command line options and INI files, this work
    is relatively straightforward. Otherwise, you can manually call
    options_set_string() for each of the search paths to configure them
    from whatever options store you are using.
    MAMETesters Bugs Fixed
    silentd0108u5yel [Mamesick]
    gradius30104u3gre [Mamesick]
    spelunk2099u6gre [robzia]
    twinactn0105u2gre [robzia]
    czeroize0108u2yel [David Haywood]
    listrom0109red [Aaron Giles]
    chdbaddump0109ora [Aaron Giles]
    ddrawcoloroverlay0109yel [Aaron Giles]
    new_debugger0109ora [Aaron Giles]
    ronnamelength0109ora [krick]
    shtngmst0108u4ora [Pierpaolo Prazzoli]
    Source Changes
    More findout.c/getrivia.c improvements: [wolf676]
    - added ticket dispenser to Trivia/Sexual Trivia
    - found last unknown dipswitch in Selection/Poker
    - added missing "Payout" button; payout hardware unknown
    - added missing "Play / Raise" button and its lamp 9
    - added "Button 12 ?" to selection, function unknown
    - re-added PORT_IMPULSE(2) to poker games buttons because they do
    not like it if two or more buttons are held; trivia games still
    respond better without this
    - changed coin_lockout_global to coin_lockout_w(0) and
    coin_lockout_w(1) for 2 coin slots in selection;
    - added missing lamps 11 (coin slot 2), 12 and 13 (unknown)
    to selection
    Fixed crash in the MPU4 driver. [El Condor]
    Hooked up ARM ROM for kovsh, though it doesn't work yet. [ElSemi]
    Some fixes for the 8080bw driver: [Robert]
    - The correct samples are being used for lrescue, lrescuem,
    grescue, desterth
    - Dipswitch corrections for superinv, invadrmr, sinvemag,
    spceking, spacewr3
    - Remove extraneous beeping noise from indianbt
    Converted all the toaplan2.c games to mono since the PCBs are JAMMA
    without external stereo connectors. [Corrado Tomaselli]
    Added bounds checking to the qsound driver. [David Haywood]
    Redesigned the OSD file I/O interfaces to be simpler and more
    straightforward. Also simplified the core's file I/O routines and
    included some functionality that was previously left to the OSD
    layer. [Aaron Giles]
    Rewrote unzip.c to return richer errors and generally behave better.
    [Aaron Giles]
    Rewrote audit.c to simplify the code and not rely on extraneous
    functions that were in the old file I/O system. [Aaron Giles]
    Simplified the 68000 core generation logic to just produce one
    file. Hopefully this will cure some of the build issues with the
    core. [Aaron Giles]
    Five a Side Soccer [Ville Linde]
    Super Street Fighter II - The New Challengers [David Haywood, stephh]
    Dynamic Shooting [Tomasz Slanina, Guru]
    Doki Doki Penguin Land [Tomasz Slanina, Guru]
    Shooting Gallery [Pierpaolo Prazzoli]
    New clones added
    The Cliffhanger - Edward Randy (World) [Patrik Styrnell]
    Double Dragon 3 (Japan) [Corrado Tomaselli]
    Twin Brats (set 2) [Patrik Styrnell]
