MAME 0.108u3
  • 0.108u3
    Source Changes
    Improved offsets of the "normal spites" in the SSV games twineag2,
    ultrax, and dynagear. [robzia]
    Added missing video change to the lethalen driver. [David Haywood]
    Some nice improvements to the debugger: [Andrew Gardner]
    * added ability to tab between views in the disassembly windows
    * added a 'cursor' to the dasm view and hooked up navigation keys
    * added F4 'run to here' key when the disasm view has focus
    * added F9 'toggle breakpoint' key when the disasm view has focus
    * enhanced memory view keyboard navigation
    Added workaround for crash in the sound code under some edge cases.
    [David Haywood]
    Fixed background ROM loading in the new wbmlbg set. [David Haywood]
    Overhauled and corrected the DIP switches in the trivia and quiz
    games in the findout driver. [wolf676]
    Added PORT_DIPLOCATION to the airbustr driver. [Roberto Fresca]
    TIA-MC1 driver improvements: [Eugene Sandulenko]
    - fixed documentation
    - hooked game counter and coin lockout
    - added save state support
    Fixed 6840 counter behavior in continuous mode. [El Condor]
    Identified some unknown DIP switches in Robby Roto. [wolf676]
    Big update to the arkanoid driver which improves emulation of some
    bootlegs: [Steph]
    - Interverted 'arkblock' and 'arkbloc2' sets for better comparaison
    - Renamed sets :
    * 'arkbl2' -> 'arkmcubl'
    * 'arkbl3' -> 'arkgcbl'
    - Changed some games descriptions
    - Removed flags from the following sets :
    * 'arkbloc2' (old 'arkblock')
    * 'arkgcbl' (old 'arkbl3')
    * 'paddle2'
    Fixed a multithreading race condition at startup. [Nathan Woods]
    Added some minimal validation on the sample rate configuration
    parameters. [Firewave]
    Fixed a few dips and added diplocation setting for Wonder Stick
    in the nmg5.c driver. [Brian Troha]
    Big update to the MPU4 driver: [El Condor]
    - added support for reverse clocking in the VFD code.
    - changed the 6840 to not run the counter clock if no frequency
    is specified
    - reworked the MPU4 drastically to be more in sync with AGEMAME
    - MPU4 video should now be working a little better
    - deprecated 6850acia.c, replacing it with a specialized driver
    Updated core.mak to ensure the make clean will remove file2str.exe.
    [Nathan Woods]
    Added new ROM loading option, ROM_IGNORE() which works just like
    ROM_CONTINUE() except that you don't need to load the data anywhere.
    It can be used when larger ROMs are present and only a portion of the
    data is used. See solomon.c for an example. [Aaron Giles]
    Removed support for the old debugger. [Aaron Giles]
    Added driver_data member to the Machine structure, where drivers can
    hang data instead of using global variables. Added MDRV_DRIVER_DATA
    macro so the core can allocate this structure at startup. Added
    AM_BASE_MEMBER and AM_SIZE_MEMBER which are similar to AM_BASE and
    AM_SIZE but let you specify a member of a struct hanging off of
    driver_data. Updated the Turbo driver to use these new features as an
    experiment. [Aaron Giles]
    More Turbo driver cleanup: [Aaron Giles]
    * doubled the horizontal resolution to better draw analog sprites
    * improved Buck Rogers and Subroc video
    New clones added
    Solomon's Key (US) [Bobby Conover]
    Commando (bootleg) [ClawGrip]
    Beam Invader (set 2) [Peter Townson]
    Connect 4 [El Condor]
    PlayMan Poker (Germany) [Roberto Fresca]
    Big Boy [David Haywood]
