Mame 107u4
  • 0.107u4
    MAMETesters Bugs Fixed
    mngrecording0107u1ora [Aaron Giles]
    vectorsnapshot0107u1red [Aaron Giles]
    tdfever087u4gra [Canim]
    quizmeku087u4gra [Canim]
    Source Changes
    Fixed the dips for Apache 3 and Dark Mist. [Brian Troha]
    Added built-in overlays for clowns and maze. [Mr. Do!]
    Converted Final Romance 2 to be dual screen. [David Haywood]
    Converted the VFD display in the BFM games to use a second screen
    rather than hacking onto the main screen. [El Condor]
    Fixed detection of left/right modifier keys when paused. Also added
    support for recently added keys so they are detected by MAME when
    paused. [Ben Rudiak-Gould]
    Changed render_target_alloc() to take a bitmask of flags. In addition
    to loading a single file, targets can also be marked "hidden", and
    only non-artwork views can be made visible. [Aaron Giles]
    Added new render target layer config flag to disable screen overlays.
    [Aaron Giles]
    Changed snapshot taking code to render the particular screen to a
    temporary render target. This allows vector games to have snapshots
    again. [Aaron Giles]
    Normalized the naming of several functions in video.c, most
    importantly: [Aaron Giles]
    force_partial_update -> video_screen_update_partial
    configure_screen -> video_screen_configure
    set_visible_area -> video_screen_set_visarea
    Added new functions that do accurate per-screen timing based on
    video parameters: [Aaron Giles]
    video_screen_get_hpos
    video_screen_get_vpos
    video_screen_get_hblank
    video_screen_get_vblank
    video_screen_get_time_until_pos
    Fixed bug that caused the VIDEO_EOF to be called repeatedly while in
    the debugger. [Aaron Giles]
    Split render.c into rendutil.c, rendlay.c, and render.c to keep the
    code more organized. [Aaron Giles]
    Abstracted the notion of outputs. A new module, output.c, now controls
    all outputs. Each output is tagged with a name; some standardization
    eventually needs to happen on these names, but at the moment it's
    fully open. The OSD layer can register with output.c to be notified
    when outputs change. From there, it is free to do what it wants. LEDs
    have now been converted to outputs with the name "led0", "led1", etc.
    [Aaron Giles]
    Added support for notifying external clients of changes in output
    states in the Windows OSD system. See windows/output.h for a list of
    messages that external clients can register to receive. Removed the
    built-in hacky LED support in the Windows OSD layer. Created a sample
    application ledutil.exe which subscribes to the external events and
    routes the "led0", "led1", and "led2" outputs to the keyboard LEDs
    just like before. If you want to continue to have LED support, simply
    copy ledutil.exe into your startup folder and let it run in the
    background. [Aaron Giles]
    Modified the Q*Bert driver to signal a "knocker0" output when the
    knocker is triggered. [Aaron Giles]
    Added new layout element component type "text", which lets you draw
    text in the built-in MAME font onto an element in a layout. This
    can be used for basic lamps and built-in layouts. See maxaflex.c for
    an example. [Aaron Giles]
    Added new layout element component type "led7seg", which constructs
    a 7-segment LED in an element in a layout. This is commonly used for
    external score and timer displays. See maxaflex.c for an example.
    [Aaron Giles]
    Added built-in layouts for Turbo, Subroc 3D, Buck Rogers, Atari
    Football, Atari Baseball, and Super Speed Racer using the new
    primitives. [Aaron Giles]
    Fixed overflow computation in the S2650 core. [Aaron Giles]
    More Sega G-80 raster cleanup: [Aaron Giles]
    * consolidated the video hardware implementations
    * fixed cocktail mode video and controls in all games
    * fixed Monster Bash (2 board version) video
    * revived Sindbad Mystery and fixed sound chip frequencies
    Trivia Quest [Pierpaolo Prazzoli]
    SunA Quiz 6000 Academy [David Haywood]
    New clones added
    Zero (set 2) [David Haywood]
