Code
- 0.107u2
- MAMETesters Bugs Fixed
- savestate0104u7ora [Adam Bousley]
- ripoff097gre [Adam Bousley]
- cuebrckj0104u2gra_fix [Canim]
- Source Changes
- Massive cleanup/fixing of 16-bit Sega drivers: [AWJ]
- * many corrections to descriptive set names, adding revision letters,
- cabinet types, etc.
- * fixed many DIP switches and added PORT_DIPLOCATION support
- * adjusted min/max values for analog controls to improve response
- * fixed button ordering between System 16A/B
- * cleaned up a number of ROM names and fixed some incorrect guesses
- * some cleanup of turbo.c as well
- * fixed visible area in Hang-On hardware
- * actually disabling 8751 in games that have a fake replacement
- * hooked up 8255 PPI correctly now that it has mode 2 support
- * fixed behavior of NMI line in later sega sound boards
- * fixed addressing in the SegaPCM sound system
- * some hardware/documentation cleanup
- Some cleanups in the new UI/video code to make MESS happy.
- [Nathan Woods]
- Added macros to prevent use of strcasecmp and strncasecmp for
- better cross-platform compatibility. [Nathan Woods]
- Connected unimplemented opcode $01 on the 6809 core. [Antoine Mine]
- Implemented CNT pin and some serial features of the 6526 CIA chip.
- [Nathan Woods]
- Mapped service button in slammast. [Canim]
- Fixed bug in 8039 CPU handling of A11 latch. [Aaron Giles]
- Rewrote Zaxxon driver from the schematics. This is still a WIP (not
- finished yet): [Aaron Giles]
- * correct clock speeds and video timing
- * complete memory maps
- * connected universal sound board to Ixion and Razmataz
- * simplified video code and merged common cases together
- * palette derived from resistor weights
- * background positioning still a little off
- Added service_coin_lockout_w() to lockout service coins. [Aaron Giles]
- Added MDRV_SCREEN_RAW_PARAMS() which lets you specify a pixel clock,
- horizontal, and vertical video timing values in place of the usual
- screen size, visible area, refresh rate, and VBLANK timing values.
- [Aaron Giles]
- Fixed bug that prevented save/restore from working in the UI.
- [Aaron Giles]
- Changed mode selection logic so that refresh is weighted more strongly
- when picking a mode. This allows you to specify -resolution 0x0@60 to
- force MAME to pick a 60Hz screen refresh while allowing it to choose
- the best resolution. [Aaron Giles]
- New clones added
- Viper Phase 1 (World, New Version) [Corrado Tomaselli]
- Wonder Boy in Monster Land (Galaxy Electronics English bootleg)
- Gals Panic II (Asia) [Patrik Styrnell]
