Mame 0.105u4
  • 0.105u4
    MAMETesters Bugs Fixed
    invaders0105u2gre [Giuseppe Gorgoglione]
    taitosj0105u3yel [Aaron Giles]
    wardner0105u3red [Aaron Giles]
    Source Changes
    Nintendo 64 system improvements: [Ville Linde, Ryan Holtz]
    - Fixed a major bug in the RSP core
    - Rewrote the PIF handling
    - Slightly improved triangle rendering
    Added a NULL check on memory_set_bankptr(), memory_configure_bank()
    and memory_configure_bank_decrypted(). [Nathan Woods]
    Added support in the debugger memory window to change the number
    of bytes displayed per row. [Andrew Gardner]
    Started simulation of orlegend super / special protection.
    [XingXing, ElSemi]
    Fixed colors and music tempo in Perfect Billiard. [Sonikos]
    Cleaned up 6840 implementation and revised scorpion2 driver's
    handling of unmapped regions. Also updated the MPU4 memory
    map. [El Condor]
    Major Toaplan 2 driver cleanup: [Quench]
    - Added Knuckle Bash 2 (kbash2)
    - Consolidated the Read/Write memory maps
    - Fixed coin counters on a few games
    - Raised the volumes on a few games
    - Cleaned the inputs by:
    Adding input inheritance and DIPSW locations
    Added conditional dependance to DIPSWs where required
    Fixing a few incorrect inputs here and there
    Fixed/improved DIP switches in the m92, afega, tumbleb, and yunsun16
    drivers. [Twisty]
    Cleaned up the liberate.c driver. [Sonikos]
    Improved ARM7 thumb mode disassembler. [MooglyGuy]
    Some improvements to Air Raid/Cross Shooter, but not playable
    due to missing gfx roms. [Tomasz Slanina]
    Fixed UI positioning when artwork is enabled. [Giuseppe Gorgoglione]
    Big pile of updates/improvements to the ARM7 core thumb mode and
    the PGM drivers. [David Haywood, ElSemi]
    Improved OKI frequency in sslam and powerbls. [f205v]
    More DIP switch improvements to m62.c, m72.c, ddragon.c. [Twisty]
    Fixed bug in the debugger that would prevent you from typing a
    command line longer than what was visible. [Aaron Giles]
    Added a new tool jedutil, which will convert .JED files to binary
    form and back again. [Aaron Giles]
    Added new ROM region REGION_PLDS, which is designed to hold binary
    dumps of PLD fusemaps (produced from .JED files by jedutil). Added
    logic to -romident to automatically parse .JED files to identify them
    against these binary dumps. Added PLD dumps to the Vindicators,
    Batman, Pit Fighter, ThunderJaws, and Relief Pitcher drivers. More to
    come shortly. [Aaron Giles]
    Converted PLDs for catnmous and lazarian to the new binary format.
    [Aaron Giles]
    Tetris (D.R. Korea) [David Haywood]
    Knuckle Bash 2 (bootleg) [Quench]
    New clones added
    Metal Slug 6 (Metal Slug 3 bootleg) [Mame32Plus]
    Metal Slug 5 (JAMMA PCB) [Mame32Plus]
    SVC Chaos - SNK vs CAPCOM (JAMMA PCB, set 2) [Mame32Plus]
    Night Slashers (Over Sea Rev 1.2) [Stefan Lindberg]
    Double Dragon (World Set 2) [Stefan Lindberg]
    DoDonpachi Dai-Ou-Jou (V100) [Wu]
  • läuft auf der pgm-hw ist aber kein mobo/cart-aufbau sondern eine jamma-pcb
    edit:
    ich sag mal: hääääääääääääää?
    kapier ich nicht welches n64-basierende system wird denn da emulliert oder um was gehts denn da??
  • nö. obwohl das ein Grund für mich wäre das zu wissen. :D
    Ich hatte das im Januar gelesen das der Herr Linde den ersten echten N64 Emu schreiben will.
    Die N64 Sache kommt im Nachhinein M.E.S.S. zugute.
    [CENTER]"Ich hack ein Loch in unser Raumschiff..."
    banner.gif[/CENTER]
  • Zitat
    Original von mac:mame
    edit:
    da bin ich aber beruhigt, das ich nicht der einzige bin/war, der sich darüber wundert/gewundert hat ;)
