MAME 0.104.u5
  • 0.104u5
    IMPORTANT CHANGE FOR OSD DEVELOPERS: a new function
    osd_create_directory is now required in order to create memcard
    subdirectories. This function was previously defined only for the
    MESS core, so if there is a MESS port already available, you can
    just import that function.
    MAMETesters Bugs Fixed
    exprraid0103u1red [Pierpaolo Prazzoli]
    asterix053gre [Pierpaolo Prazzoli]
    asterix_2055gre [Pierpaolo Prazzoli]
    asterix_3055gre [Pierpaolo Prazzoli]
    namcos10104u4red [Aaron Giles]
    rthunder0104u3ora [Aaron Giles]
    memorycard0104u2ora [Aaron Giles]
    pause0104u2ora [Aaron Giles]
    undrfire0104u4yel [Aaron Giles]
    wwallyj0104u4red [Aaron Giles]
    scorpion0104u4red [Aaron Giles]
    itech8c0104u4red [Aaron Giles]
    Source Changes
    Hooked up missing language jumper in the Psikyo 4 games.
    [David Haywood]
    Added board notes to the Namco System 12 driver, hooked up the light
    gun in Ghouls Panic/Point Blank 2, and emulated Tekken Tag Tournament
    DMA protection (still not playable). [Olivier Galibert, Duddie, smf]
    Fixed old debugger compilation on non-Windows platforms. Added
    mame_strnicmp along the way. [Lawrence Gold]
    Fixed compile errors under GCC 4.1. [Lawrence Gold]
    Changed the NES PPU interfaces to follow new struct conventions.
    [Nathan Woods]
    Updated disassembly comments support: [Andrew Gardner]
    - fixed a 0-length comment bug (no more "// 0, " allowed)
    - added comment output to the new debugger's dasm command
    - changed the comment save path from /mame/comment to /mame/comments
    Added new debugger properties: logunmap, logunmapd, logunmapi which
    enable/disable logging of unmapped memory accesses. [Nathan Woods]
    Added save state support to the Astrocade driver. [Adam Bousley]
    Some small improvements to the Polygonet Commanders driver.
    [Andrew Gardner]
    Preliminary Thumb implementation for the ARM7 core. Many opcodes
    present, but there are definite sign problems. [Ryan Holtz]
    Hooked up ARM7 protection CPU in KOV2. Boots but does not run or
    play due to the Thumb sign problems. [R. Belmont]
    Fixed incorrect flags emulation in the 8080 CMA instruction.
    [Kopromaster]
    Added support for zero-length palettes (requires RGB direct mode) and
    several validity checks related to display variables. [Nathan Woods]
    Updated windows input code: [Derrick Renaud]
    * Now using RAWMOUSE mode if available. This means you can now use
    multiple mice in Windows XP. Lightgun support has not been
    changed yet.
    * Added back DX7 support for the windows input system to support
    multiple mice. It was set to DX5 in 104u2.
    * Removed the system mouse from the list of available mice on
    non-XP systems. This allows you to now properly select the
    individual mouse.
    * Modified the Analog Axes selection of the player controls to be
    more responsive.
    Cleaned up video system in Scorpion 2 driver. [El Condor]
    Converted asterix to use K056832 emulation. [Pierpaolo Prazzoli]
    Reduced encryption in Gaelco games down to equations. These still
    need to be optimized, but the giant encryption tables are no longer
    needed. [Nicola Salmoria]
    Cleaned up include files in CPU/sound cores. CPU cores should
    generally only need to include cpuintrf.h. Sound cores should
    generally only need to include sndintrf.h. [Atari Ace, Aaron Giles]
    Fixed bug that caused a full set of validity checks even on release
    builds. [Aaron Giles]
    New debugger features: [Aaron Giles]
    * new command "print" is a simple way to display the result of one
    or more expressions
    * new command "symlist" displays all the symbols registered
    * all save state registered scalar globals are now available as
    symbols (prefixed by a '.')
    * all save state registered global arrays are now available for
    viewing/editing in the memory window
    * all registered memory regions are also available for viewing/
    Made it a fatal error to request operations on invalid sound/CPU
    indexes. These have been logged to the error.log in the past, but
    really need to be cleaned up. Added a new function
    safe_activecpu_get_pc() that can be used when logging PCs to smartly
    detect whether or not it is safe to call activecpu_get_pc().
    [Aaron Giles]
    Changed CPU init/reset callbacks. The init callback now accepts a
    number of parameters, including the CPU index, the clock, a generic
    configuration parameter, and a pointer to the IRQ callback. The reset
    callback no longer takes any parameters (the configuration parameter
    has been moved to the init callback). And the IRQ_CALLBACK getter/
    setter has been removed since this is now set up once at
    initialization time. [Aaron Giles]
    Added mame_get_phase to determine which program phase (init/reset/
    running/exit) the system is in. This is intended primarily for
    assertions to enforce rules about when certain actions can be taken.
    [Aaron Giles]
    Rewrote winalloc to be more dynamic, and to ignore memory leaks in
    the runtime. [Aaron Giles]
    Fixed memcards properly. They are no longer hardcoded for the neogeo.
    The implementation has moved to generic/machine.c, and a callback
    handler very similar to NVRAM is now supported in the machine driver
    definition. Cards are created per-game, so the memcard directory now
    has a subfolder per game with each game's cards stored underneath.
    [Aaron Giles]
    New clones added
    Fighters Swords (Korean rel. of Samurai Showdown III) [Haze, Razoola]
    Art of Fighting 3 (Korean release) [Haze, Razoola]
    The Last Solider (Korean release of The Last Blade) [Haze, Razoola]
    Real Bout Fatal Fury 2 (Korean release) [Haze Razoola]
    Tekken 3 (TET2/VER.B) [smf]
    Soul Calibur (SOC11/VER.C) [smf]
    Point Blank 2 (GNB5/VER.A) [smf]
    Tekken Tag Tournament (TEG1/VER.B) [smf]
    Tekken Tag Tournament (TEG1/VER.A3) [smf]
    Golgo 13 Kiseki no Dandou (GLS1/VER.A) [R. Belmont]
    Pollux (set 3) [ClawGrip]
    Out Zone (set 4) [Tormod Tjaberg]
    Gamshara [smf]
    Taisen Hot Gimmick 4 Ever (Japan) [Guru, David Haywood]
    Taisen Hot Gimmick Integral (Japan) [Guru, David Haywood]
    Mahjong G-Taste [Guru, David Haywood]
  • New Game Available!
    I've recently been in contact with Duncan Brown, the guy who wrote Alien Arena, which was recently added to MAME. Alien Arena was an entirely new game (in 1985) that was designed to run on the classic Williams hardware. Duncan owned an arcade at that time, and he actually put the game on location there with the hopes of making it into a more widely distributed conversion kit for arcade operators.
    Duncan has been kind enough to allow us to make his game available free for non-commercial use, just like the other games in the ROM Images section. So I invite you to check it out, read more about the history of the game, and enjoy playing something new. Duncan has even provided his email address in the enclosed readme, so feel free to drop him and line and let him know what you thought about it!
