MAME 0.104.u4
  • 0.104u4
    IMPORTANT CHANGES FOR OSD DEVELOPERS:
    1. osd_pause is no longer called directly. Rather, your osd_init
    function should register the osd_pause callback (if necessary) using
    add_pause_callback.
    2. osd_die is now handled by the core; you should remove this
    function from the OSD layer.
    3. logerror is front-ended in the core; it calls to a new OSD
    function osd_logerror which handles the OS-specific file and/or
    debugger logging.
    MAMETesters Bugs Fixed
    memwindow0104u3red [Aaron Giles]
    i9600104u2ora [Aaron Giles]
    dietgo0104u2red [Aaron Giles]
    st0016_0104u3red [Aaron Giles]
    8751MCUgames0104u3 [Aaron Giles]
    warriorb0104u2gre [Pierpaolo Prazzoli]
    cheat0104u3ora [Ian Patterson]
    Source Changes
    Added comments support to the debugger. You can now dynamically add
    comments that are visible next to the disassembly view. Comments are
    saved to an XML-based .cmt file in a 'comments' directory by default
    upon exiting. [Andrew Gardner]
    Added "wb+" disposition to osd_tool_fopen. [Nathan Woods]
    Fixed cheat timer to fire at the correct rate. Also fixed
    initialization order to work around dependency on the video/UI
    system. [Ian Patterson]
    Added save states to 3 more drivers: arkanoid.c, system1.c, and
    taitosj.c, and to the SN76496 sound chip for system1. [Adam Bousley]
    Fixed a couple of small memory leaks and a crash bug found by
    valgrind. [Lawrence Gold]
    Added save state support to the tetrisp2 driver. [Nathan Woods]
    Added save state support to Cloak and Dagger, Mario Bros, Crazy
    Baloon, and the SN76477 sound chip. [Adam Bousley]
    Hooked up the R4650 properly in the MIPS recompiler. [R. Belmont]
    More Namco System 23 progress: [R. Belmont]
    - Further hardware work
    - Hooked up H8/3002 MCU and sound system
    - Many notes added
    - Final Furlong 2 (World and Japan sets) added
    Added sanity checking to the set_visible_area() call to ensure it is
    not set larger than the screen bitmap. [Nathan Woods]
    Added decryption of the BIOS for the Namco System 10 games using MEMN
    ROM boards. [smf]
    Changed the ROM banking of the Bellfruit 'Adder' card to the new
    standard, as well as tidying up the MPU4 emulation with some new
    information. [El Condor]
    A bit more progress on Raiden 2 sprite decryption. [Olivier Galibert]
    Added save states to Namco Classics Collection 1 & 2, Taito B System,
    and fixed save states in Operation Wolf. [Adam Bousley]
    Debugger changes/updates: [Aaron Giles]
    - added new streaming text buffer system
    - rewrote the console window to use the streaming text buffer
    - added new log window (Ctrl+L) which displays live error.log output
    - added disassembly view menu to control comments versus raw or
    encrypted opcodes
    - added disassembly menu to the main console window as well
    - now detect expressions with assignment or ++/-- operators as
    commands, do you can just say "pc=0" to modify registers instead
    of needing to type "do pc=0"
    - fixed bug that would sometimes lock the disassembly view to the
    top line
    More global system cleanup: [Aaron Giles, Atari Ace]
    - remapped osd_die to fatalerror, which cleans up behind itself and
    returns to the osd code by returning from run_game
    - removed a number of unnecessary includes from driver.h
    - moved logerror into the core
    - moved 68000-specific build rules to cpu.mak
    - new function skip_this_frame, should be called by drivers instead
    of osd_skip_this_frame
    - removed includes of osdepend.h and osd_cpu.h from drivers; only the
    core should include these
    More initialization/reset/pause cleanup: [Aaron Giles]
    - new function add_pause_callback can be called by other modules to
    register a callback for whenever MAME is paused/resumed
    - converted all existing pause hooks to use the new system
    - new function add_reset_callback can be called by other modules to
    register a callback for whenever MAME is reset
    - converted all existing reset hooks to use the new system
    - removed machine_reset; replaced with mame_schedule_soft_reset
    - new function mame_schedule_exit to force an exit cleanly from
    external events
    - removed all the "trying_to_quit" crap from the Windows code
    - moved save/restore system out of cpuexec.c into mame.c
    - moved core game loop out of cpuexec.c into mame.c
    - added hard reset support (complete tear down and re-init)
    More core file shuffling: [Aaron Giles]
    - split sndintrf.c into sound.c, sndintrf.c, and sndhrdw/generic.c
    - added #include vidhrdw/generic.h to mamecore.h, and removed all
    explicit includes elsewhere
    Added save state support to the BSMT2000 sound emulator and the
    dcheese driver. [Aaron Giles]
    Fixed missing save state data in the dkong driver. [Aaron Giles]
    Updated the 68000 disassembler to use the new interfaces.
    [Aaron Giles]
    Fred Flintstone's Memory Match [Aaron Giles]
    New clones added
    Dragon Breed (M81 pcb version) [Pierpaolo Prazzoli]
    Crazy Fight [Pierpaolo Prazzoli]
    Search for the Magical Error [David Haywood]
    Final Furlong 2 [R. Belmont]
    Gekitoride-Jong Space [smf]
    Mr. Driller G [smf]
    Kotoba no Puzzle Mojipittan [smf]
    Star Trigon [smf]
