Mame 0.104
  • 0.104
    MAMETesters Bugs Fixed
    centiped0103u3ora
    Source Changes
    Fixed tiny.mak for the changes from 0.103u5. [Derrick Renaud]
    Fixed NVRAM handling in Star Wars/ESB (only affects test mode).
    [Mathis Rosenhauer]
    Decrypted the question ROMs in the coinmstr.c games. [Nicola Salmoria]
    Updated djboy driver with more protection information.
    [Phil Stroffolino]
    More NeoGeo cleanups. [David Haywood]
    Phoenix Discrete Sounds - Changed R22 to 470 ohm per real board. This
    should fix the remaining complaints with the discrete sound. The shot
    & explosion noise sounds still need discrete emulation.
    [Derrick Renaud]
    Added 16-segment drawing code to the vacfdisp module. [El Condor]
    Made 8-bit A,B,C,D,E,H and L registers available in the Z80
    debugger. [Nicola Salmoria, Aaron Giles]
    Ensured that all core and windows files have some indication of
    copyright on them. [Aaron Giles]
    Shuffled a few more files around in mame.mak; rebuild clean once
    again to ensure correctness. [Aaron Giles]
    Removed all but the default debugger font from the source
    distribution. [Aaron Giles]
    Fixed miscomputed registers view size in debugger. [Aaron Giles]
    Lord of Gun (USA) [Luca Elia]
    New clones added
    Trivia ? Whiz (Vertical versions) [Pierpaolo Prazzoli]
    Trivia ? Whiz (Edition 4) [Pierpaolo Prazzoli]
    Phraze Craze (Sex Kit) [Pierpaolo Prazzoli]
    Police Trainer (Rev 1.0) [Brian Troha]
    Huang Fei Hong [Luca Elia]
  • February 05, 2006
    MAME 0.104, take 2
    A last minute bug was found that caused -listxml to crash. If you downloaded the source and it has this crash, I've put up a fixed set of sources (same name).
    If you already downloaded the sources and want a quick fix, just grab and apply this diff.
    Posted by Aaron at 07:43 PM
