MAME 0.103u4
  • 0.103u4
    MAMETesters Bugs Fixed
    xevious083gre [MASH]
    Source Changes
    Intel i386/i486/Pentium update: [Nathan Woods]
    - Fixed A20 mask implementation
    - Added A20 mask to debugger translate callback
    - Implemented Pentium opcode CMPXCHG8B
    - Fixed XADD, and added support for the 8 and 16 bit variants
    Fixed Top Shooter sprites. Game still not playable. [Tomasz Slanina]
    Changed debug view property code to pass property values as unions rather
    than void pointers, in order to appease compilers that whine about strict
    aliasing. [Nathan Woods]
    Fixed resource allocation issue with bitmaps in the Windows code and
    MESS. [Nathan Woods]
    Removed a number of unnecessary video_stop and machine_stop routines.
    [Atari Ace]
    Converted a few more exit() calls to osd_die(). [Oliver Stoneberg]
    Fixed inputs on Ninja Spirit and the Sega System 16b driver to match the
    JAMMA button ordering. [Corrado Tomaselli]
    Fixes to the Hyperstone core: [Pierpaolo Prazzoli]
    - Removed nested delays
    - Don't allow software opcodes to be executed in a delay slot
    Added/changed the following discrete modules: [Derrick Renaud]
    - DISCRETE_WAVELOG - easy way to log discrete nodes as a .wav file to
    compare against scope waveforms.
    - DISCRETE_OUTPUT - added a final gain parameter to get it to 16 bit
    wav level. (The old VOL setting was disabled after the last sound
    re-write.)
    Fixed graphics banking in 8751-based Altered Beast sets. [David Haywood]
    Fixed some bad gfx in kdynastg when levels start. [Pierpaolo Prazzoli]
    Decrypted graphics in Darkmist and Panic Road. [Nicola Salmoria]
    Added stream_set_sample_rate() call, and converted the TMS5110, TMS5220,
    ES5505/6, BSMT2000, AY8910, POKEY, TIA, Sega PCM/Multi-PCM, SN76496,
    OKIM6295, and YMZ280B sound cores to output at their native sample rates,
    allowing the core sound system to perform over/re-sampling to the output
    rate. [Aaron Giles]
    Moved CHD file access routines to fileio.c. [Aaron Giles]
    Added assert macro to mamecore.h. [Aaron Giles]
    Laser Battle/Lazarian [Pierpaolo Prazzoli]
    Cat and Mouse [Pierpaolo Prazzoli]
    KlonDike+ [Pierpaolo Prazzoli]
    Alien Arena
    Crowns Golf in Hawaii [Aaron Giles]
    New clones added
    Joust (Solid Green Label) [Reznor007]
    Space Intruder (Japan) [Tomasz Slanina, Guru]
    Galaxia [David Haywood]
