MAME 0.103u1
  • 0.103u1
    MAMETesters Bugs Fixed
    upsidedown0103yel [Mamesick]
    Source Changes
    Major cleanup/rewrite of the Berzerk driver: [smf]
    * merged memory & io read/write maps.
    * video ram & magic ram share the same memory.
    * hooked up nvram in frenzy memory map.
    * emulates magic ram shifter/flopper with 9 74LS153's as per the
    schematics.
    * emulates magic ram alu with 2 74LS181's hardwired to logic mode as
    per the schematics.
    * 74LS181 emulation based on the logic diagram from the datasheet,
    supporting logic mode & arithmetic mode
    Fixed Thunderstrike interrupts, visible area, and raster updates.
    [Bryan McPhail]
    Updates for the ARM core: [Bryan McPhail]
    * Fixed software interrupts.
    * Fixed several mode change bugs.
    * Preliminary coprocessor support.
    Deco fixes: [Bryan McPhail, Pierpaolo Prazzoli]
    * Deco MLC video hardware near perfect for the most part, however no game
    works properly because of an unemulated math coprocessor attached to
    the DE156 chip.
    * Deco 32: Night Slashers pretty much perfect apart from lack of sound.
    * Deco 32: Some graphics fixes for Tattoo Assassins.
    * Deco 156: Heavy Smash pretty much perfect.
    Tagged a number of constant arrays in the source as static. [Atari Ace]
    Many H6280/PCE fixes: [Rob Bohms, Charles MacDonald]
    - fixed cases where sprites could render outside of the buffer
    - added VRAM to VRAM DMA (Charles)
    - multiple h6280 fixes (Charles)
    - provided functions to correctly handle VRAM accesses for the entire
    128K range (Charles)
    - added some of the I/O buffer bits from the hardware page
    - fixed h6280 IRQ ranges to support proper mirroring
    - hooked up h6280 IRQs to the PC Engine
    - corrected sprite-to-sprite rendering priorities.
    - partially enforce 16 sprite limit
    Added new debugger command traceflush. [Nathan Woods]
    Fixed out-of-bounds array writes in the v810 core. [Atari Ace]
    Moved several BCD and date-related functions into mamecore.h. [Nathan woods]
    Hooked up sound effects in Triple Hunt. [Derrick Renaud, Stefan Jokisch]
    Fixed OKI frequency in Super Model. [Sonikos]
    Added PowerPC MMU code, but enabled only for MESS due to breakage of the
    Model 3 games. [Nathan Woods]
    Fixed graphics layer priority in Grand Tour. [Tomasz Slanina, Guru]
    Rewrote the Star Wars mathbox multiplier from the schematics.
    [Mathis Rosenhauer]
    Night Slashers [Bryan McPhail]
    Heavy Smash [Bryan McPhail]
    Avengers In Galactic Storm [Bryan McPhail]
    Power Instinct Legends [Brian Troha, Pierpaolo Prazzoli, Guru]
    Shuttle Invader [Tomasz Slanina]
    Mahjong The Dai Chuuka Ken [Luca Elia, Guru, bnathan]
    New clones added
    Pasha Pasha Champ Mini Game Festival [Pierpaolo Prazzoli]
    Thunder Strike (Newer) [Bryan McPhail]
    Super Star Battle [Pierpaolo Prazzoli]
    Quiz (Revision 2.1) [Pierpaolo Prazzoli]
    Mirax [Tomasz Slanina]
