MAME 0.102u2
  • 0.102u2
    MAMETesters Bugs Fixed
    f1en097u1gre2 [Anonymous]
    ozmawars055gre [RansAckeR]
    Source Changes
    Some minor cleanups to the System 32 driver. Air Rescue and F1 Exhaust Note
    now share common multi-PCB faking logic. [Anonymous]
    Properly hooked up tape samples in Thief, NATO Defense, and Shark Attack now
    that sample pausing is available. [Bart Tobalske]
    Fixed several uninitialized variables, incorrect string compares, and
    inconsistent variable declarations found by the VC compiler. [Oshah]
    Fixed 16-bit i386 disassembly so it stays within the current segment.
    [Nathan Woods]
    Some minor Turbo Sub changes: [Philip Bennett]
    * Added some more notes.
    * Corrected some hardware functions in accordance with the schematics.
    Tweaked the 68000 disassembler to display F-line traps in a more obvious
    fashion. Also changed to decorate jump targets for relative branches.
    [Alex Jackson]
    Rewrote the Voodoo emulation code to be more accurate to the original.
    * Support for multiple simultaneous boards (hello Silent Scope)
    * Pixel-pipelined framebuffer accesses now work
    * Alpha buffer operations now supported
    * Triple buffering now supported
    * Proper memory allocation and handling based on configuration
    * Proper FIFO handling, including low/high water marks and stalling
    * Approximate timing calculations based on quoted fill rate specs
    * Detail textures implemented
    * All math is done in fixed point
    * Proper edges calculated for polygons (stars appear in Gradius 4 now)
    * Much easier to add specific rasterizers now
    This is a work in progress; some stuff is not quite right yet. Voodoo 2
    emulation is completely broken. [Aaron Giles]
    Lovely Pop Mahjong Jan Jan Shimasyo 2 [Guru]
    New clones added
    Trivia Master (set 2) [Pierpaolo Prazzoli]
    Tech Romancer (EURO 980914) [Arzeno Fabrice]
    Splatter House (World) [Arzeno Fabrice]
    Strider 2 (USA 991213) [Brian Troha]
    Touch & Go (World) [Stefan Lindberg]
    Wonder Boy (system 2) [David Widel]
    Kageki (World?, hack) [David Haywood]
    Fighting Vipers 2 [Ville Linde]
    Tang Tang [David Haywood]
    Spectrum 2000 [David Haywood]
    Spikeout [Ville Linde]
    Spikeout Final Edition [Ville Linde]
