Mame 0.101u1
  • 0.101u1
    WARNING: There is a significant change to the memory system in this version.
    It is likely that a number of games are broken. Please report these games
    to http://www.mametesters.org.
    MAMETesters Bugs Fixed
    galpanic0100u4yel [Pierpaolo Prazzoli]
    Source Changes
    Integrated 53C810 into the SCSI framework. [Tomas Karlsson]
    Balanced the sound in Final Tetris, Boogie Wings, B.C. Story, Metal Saver.
    [sonikos]
    Fixed Q*Bert knocker connection. [Kevin Jonas]
    Some improvements to M37710, C352 and NamcoNA sound. [cync]
    Corrected CPS1 frequencies based on measurements from a real PCB.
    [Philip Bennett]
    Significant change to the memory system. RAM areas are now no longer
    allocated out of the memory_region for a given CPU. This means that drivers
    which assume that RAM is located at some offset to the base of the memory
    region will be broken. [Aaron Giles]
    Added save state information for streams so that dynamic volume changes
    get properly restored. Unfortunately this breaks all existing save states.
    [Aaron Giles]
    Added save state support to the HC55516 sound chip. Added save state support
    to the Williams sound boards. Added save state support to games in the
    mcr3.c and mcr68.c drivers, marking them as GAME_SUPPORTS_SAVE. [Aaron Giles]
    Changed timer_alloc_ptr-style timers so that the pointer parameter is
    supplied at allocation time and is not changeable. This makes these timers
    more easily supported in save states. [Aaron Giles]
    Fixed missing save state registrations in the m6809 CPU core. [Aaron Giles]
    Deferred state loading until all anonymous timers have cleared. This fixes
    issues where the timers would fire after the load and would clobber data
    that was just loaded. [Aaron Giles]
    Cleaned up and fully mapped the Williams sound boards. Also added save state
    support to them. [Aaron Giles]
    Added save state support to the classic Williams drivers, marking them as
    Chewing Gum [f205v]
    New clones added
    Puzz Loop (Korea) [Corrado Tomaselli]
    Get Bass [Ville Linde, Guru]
    Scud Race Plus [Ville Linde, Guru]
    0.101u1
    Source Changes
    [sonikos]
    [Philip Bennett]
    [Aaron Giles]
    Chewing Gum [f205v]
    New clones added
    [CENTER]"Ich hack ein Loch in unser Raumschiff..."
    banner.gif[/CENTER]
