0.100u2
MAMETesters Bugs Fixed
pepper20100u1red [Aaron Giles]
exidy440c0100u1red [Aaron Giles]
ldrun0100u1gre [Pierpaolo Prazzoli]
orld105k079yel [Mamesick]
fromanc4099u2gre [Mamesick]
Source Changes
Fixed bug that caused VIDEO_EOF routines to be called while paused. This led
to weird graphics and out of timers messages in some games. [Aaron Giles]
Improved redhawkb DIP switches. [Roberto Fresca]
Separated Sega C2 driver into several other pieces. [David Haywood]
Changed m72 video updating to use partial updates. [Aaron Giles]
Replaced old Prop Cycle input hacks with proper analog control. For best
results, delete your propcycl.nv file and calibrate (same procedure as
Cyber Cycles and Final Lap R) before playing. [R. Belmont]
Fixed error message when auditing optional files. [smf]
Bumped interleave in the elecyoyo driver to avoid attract mode hang. [MASH]
Flipped solarq overlay. [MASH]
Updates to the Sega C2 driver: [Aaron Giles]
* got Twin Squash working
* fixed column scroll with a line scroll of 8
* cleaned up input ports
* cleaned up Ribbit protection implementation
* fixed protection for Print Club games
* filled out memory map according to cgfm's documentation
* hooked up protection for Print Club v.2, 4, 5
Implemented raster split interrupt in System FL games, making Final Lap R
work fully. [El Semi]
Cleaned up driver flags and parent/child relationships in the funworld
driver. [Roberto Fresca]
Small NSS update: [R. Belmont]
* Fixed disassembly of 2 SPC700 instructions
* Fixed behavior of the APU port clear flag to not clobber the output
ports - games now can boot and run without the "APU skipper"
* Fixed SPC700 CMP instruction flags
Some under-the-hood debugger changes: [Olivier Galibert]
* Added an osd-private void * to debug_views
* Made view sizing more dynamic
Lup Lup Puzzle [Pierpaolo Prazzoli]
Twin Squash [Aaron Giles]
Cool Minigame Collection [Pierpaolo Prazzoli]
Golden Axe - The Duel [Mariusz Wojcieszek]
New clones added
Moon Light [Roberto Fresca]
Final Crash (World, bootleg) [David Haywood]
Golden Tee Supreme Edition Tournament (v5.10) [Brian Troha]
NBA Play By Play [Ville Linde]
Top Shooter [David Haywood]
