Hi,
die sind vorgeben. Man kann zwischen 4 verwschiedenen Layouts auswählen.
Guck mal ins Manual - > Working Modes
[h=2]PC[/h]In the PC working mode the Dual Strike works as a game controller for PCs with an operating system supporting HID (e.g. Windows 7/Vista/XP/2K/98, Mac OSX and Linux), no separate drivers are needed. To use it the first time with enabled working mode auto-detection you have to explicitly start the PC mode to install the drivers (see Mode Selection).
The joystick directions are sent to the host as a digital pad. The joystick directions are sent to the device as either digital pad (Windows: POV hat), left analogue stick (Windows: X and Y axis) or right analogue stick (Windows: Z axis and Z rotation) directions, see Joystick Function/MAME Mode Switching for how to change it. The other mappings are:
Button |
Windows |
[h=2]
MAME[/h]In the MAME working mode (not available for ATmega8) the Dual Strike works as a HID compliant keyboard (i.e. on operating systems like Windows 7/Vista/XP/2K/98, Mac OSX and Linux) with the MAME default keys mapped to the stick buttons, thus it is a MAME keyboard encoder. Three modes are available:
the game modes (meant for playing your games) for player 1 as well as for player 2
- and the control mode (for configuring game specific options).
To switch between them, use Meta+Left for player 1 and Meta+Right for player 2 game mode and Meta+Up for control mode or an appropiate switch, see Joystick Function/MAME Mode Switching for details.
IMPORTANT: The key for the Meta Button is activated by button release, if no combination containing it was pressed.
[h=3]Game Modes[/h]The inputs are generated either for player 1 or player 2.
The direction and special inputs in the game modes are:
Dual Strike |
MAME |
Player 1Keyboard |
Player 2Keyboard |
If Start+Select=Home is activated, then Start+Select means P.
The standard MAME key assignments are assumed for the buttons:
MAME |
Player 1Keyboard |
Player 2Keyboard |
- - - Aktualisiert - - -
Zischen folgenden Layouts kann man wählen
How these MAME buttons are mapped to the stick buttons LK, MK, HK, 4K, LP, MP, HP and 4P is determined by the configuration of the Dual Strike. There are four button mapping sets. A set is activated by pressing Meta+LP together with a joystick direction. The first is activated by Up, the second by Right, the third by Down and the fourth by Left. You can use the configuration editor to change these. The default button mappings are given below.
[h=4][/h][h=4]Default Button Layout 1[/h]This layout is activated by pressing Meta+LP+Up.
Dual Strike |
MAME |
[h=4]
Default Button Layout 3[/h]This layout is activated by pressing Meta+LP+Down.
Dual Strike |
MAME |
[h=3]
Control Mode[/h]The following input mappings apply to the control mode:
[TABLE]
